| CNC Wood Router Project Log Post your CNC machine building log here only. |
Here's a question I've seen thrown about alot but with no real conclusions. How does one keep wood dust out of the lead screws, and why don't the nuts come with wipers preinstalled? I have it in my mind to mount my old shop vac under the bench and then run a hose up to the router bracket on a suspended wire with some small pullies attatched to the hose so as not to foul the movement. All well and good but, how well will it pick up dust at the cutter area? Are these motors in the vacs able to be throttled down with speed reducers used for wood routers? Any commemts and ideas are welcome. Let work together and solve this cruddy question for all our good. Thanks for any input we all will give. |
| Well, let's start with the fact that not all applications for ballscrews involve dusty/dirty environments. Among other places, they're found on the bottom of electrical hospital beds. Fluids might be an issue...but dust certainly isn't. Probably only a relatively few ballscrews end up in cutting tools like ours. So, why would they put an unnecessary part on them (thus raising the cost) by default? I just wish better wipers were easily available. -- Chuck Knight |
| related thread that title search misses... A very unexciting project.......... |
| OK, so I missed that one. Some good ideas but few conclusions. Yes I know, all of us have different applications, different needs. I was hoping to get us all working together on this and create an aplications tutorial about dust management, noise control, the works. Still interested anyone? |
| I recently bought a Grizzly variable speed router and it came with a neat little dust grabber that fits on the base near the cutter, by the looks of it this item will solve the pick up issues very nicely. I think this issue is history. Over and out.. |
| Whatzup is that there are alot of solutions....you can use springy, accordian, etc. rail covers....you can add wipers to the ball nuts and then there are all the dust collector options. You have to design a system for your needs. |
#10
| Good morning everyone. I am a newbe but I have been reading the posts on the zone and have not seen this idea before. If it is a repeat just ignore it. To keep the dust out of the leadscrews & off of the bearing shafts I was thinking of useing dryer vent hose, you know the slinky with a sleeve over it LOL, you can get it in several sizes and it is verrrry cheap! Let me know if anyone has tried this before. Thanks Jimmy |
#11
#12
. Also with the width you would not have to worry about pick-up even with vcarving etc plus they give so when you drill holes the hose gives and stays against the surface. (Clear hose would be nice) I would think with plexi glass, maybe could add memory foam around the rim of the hose.I will be working with this idea and post images. BTW how do I get images directly onto my posts do i need to upload them to my profile first? either way I can atleast pull them from my server with a hyperlink so they can be viewed. |
| G-Code to DXF | WayneHill | OpenSource Software | 189 | 01-30-2012 11:15 AM |
| Stepper control software suggestions | jlawren6 | General CAM Discussion | 6 | 05-21-2011 06:42 AM |
| Visual Basic Controller Project | dwwright | Visual Basic | 29 | 02-14-2011 02:24 PM |
| CNC Glossary | CNCadmin | CNCzone Club House | 17 | 03-09-2008 04:08 PM |
| HAAS Indexer Prodramming / Control | CAMmando | Haas Mills | 8 | 06-10-2003 11:22 AM |
