| CNC Wood Router Project Log Post your CNC machine building log here only. |
#49
| Well, I'm still using the machine, it works fine so I didn't tear it apart. The new one I'm working on is a larger format, about 36'' wide by 50'' long with motors on both sides of the long axis. Ive got two Yaskawa 200 Watt ac drives and motors with absolute encoders that have batteries so they remember thier position one for each side. The idea is to be able to set it over a piece of plywood and work a section of a full sheet. I have the gantry and z axis done I'm just stuck on driving the long axis without having a screw underneath, exactly what you had problems with. I dont know weather I'll end up running two belts or two racks yet. Here are some pictures of what I've done so far, but I kinda got stuck with these absolute encoders. Just wiring them and setting up the drives is crazy.
__________________ Halfnutz (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#50
| Well it looks like a fantastic start thats for sure, would like to help with the electronics but when it comes to that I,m not to keen.Seeings I already have a Y&Z assembly I thought of another way of doing my gantry, what do ya think. |
#51
| That is similar to some really rigid designs I've seen and will give you the added height as well. Brace the inside of the corners and you will add even more stiffness!
#52
![]() Are thoes bellows homemade? Sewn or glued? Thanks for posting, do you have a build thread? |
#53
| Hello Mr Chips, the bellows were purchased, the material is like a neoprean inside with a weaved type material on the outside and are sowen. I don,t have a build log of this machine, but soon as I get some 1/2 inch toolling plate I,ll post as I go along.I finished tripple checking my measurements today and will be placing my order.? whats the difference between ball screw and lead screw? What would be best for my setup keeping in mind that I,ve previously run this machine for 6 to 8 hours at a time, cheers and thanks, by the way like what you are doing Mr. Nuts. |
#54
| Halfnutz, Spend a lot of my time scrounging for aluminum & brass at IMS, Irvine (Santa Ana??) Have you noticed how the prices of cut stock have been escelating? DIX was always a better source for random cuts when they were in the area, but since they moved to Huntington Beach I haven't used them. Do you know if they have a surplus stock outlet at the new location? Enjoy watching your thread, you are doing some real good stuff!! W. Smith, Mission Viejo, CA |
#55
| Thanks, CNCFun&Games, I haven't been doing much lately, but I probably turn on my machines and play around cutting air almost every day, I just love to watch and listen to the music..... Yes IMS is where I shop usually and I have definately noticed the prices skyrocket. I remember when I built my first machine, I came home with so much metal it was great, for less than a hundred bucks I got an incredible amount of stuff. Now thats what they want for a couple of pieces of aluminum. I've never been to the place in Long Beach, is it any cheaper? Probably the same as everything is tied to price per pound that the metal's going for as scrap. I would love to know of some scrap yards around here to rumage through, I bet there are a few in Santa Ana, but I dont know where. Ebay is where I get most of my extrusions at, but 80/20 prices went through the roof as well over the last couple of years. It probably has something to do with China buying so much raw goods.
#57
| HELP! I am trying to figure out a decent way of holding 1/8 in. or 3/16 in. endmill shanks in my 1/4 in. router collet. I tried making something today, but I dont trust it and would like to see what others have done instead of re-inventing the wheel. __________________ Halfnutz After much searching I went down to the local Sears hardware department and picked up a 1/4" to 1/8" adapter for about $8.00. It's intended for a Rotozip so it's rated for high rpm. Holds the bit with an Allen setscrew and seems acurate enough for most work. |
| Trade offs between Moving Gantry and Moving Table | gregmary | DIY-CNC Router Table Machines | 11 | 04-22-2011 01:48 PM |
| Open Team Cheap DIY CNC Moving Gantry Router | pminmo | DIY-CNC Router Table Machines | 94 | 08-19-2007 01:59 PM |
| Collapsable router table? | samualt | DIY-CNC Router Table Machines | 3 | 03-27-2007 09:02 PM |
| Moving Table vs Moving Gantry; Dremel vs Router | chuckknigh | DIY-CNC Router Table Machines | 32 | 03-27-2007 08:48 PM |
| Gibbs and a gantry style router | bgolash | GibbsCAM | 1 | 12-18-2004 12:24 AM |
