You'll come closer to getting your answer over in the ArtCam Pro forum
here. This is a build log forum.
CarveOne
our new Jcut router is alive but can't get it to do much..In artcam 7, I can't find a MMG. file extention to save and open in ncstudio 5.4..China gives me no help..I know that it needs G code to run the table how do I get this MMG. ext?? Any help would be great!
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
Why not, I use MMG to save toolpath in artcam 7 as well as other versions
So there is option availabel to save toolpath in MMG(modelmaster)
santosh
INDIA
I have found how to save .mmg files in Artcam 7. That works and I can open and cut with NcStudio.
Now I am importing muliple items to a model which I have set up to be the size of my material. It seems to take a long time to import each item and after I place them on my sheet, I nest them and for some reason, I get objects on to of objects. Any help? Also, I can just save the toolpath without nesting as a mmg and that works.
We also have a plasma cutter that uses Pronest and that works well. Anyone have any experience with Pronest and a CNC router?
