| CNC Wood Router Project Log Post your CNC machine building log here only. |
#217
| New upgrade, Tooling plate! Always start with a plan! Made a wood piece to test fit the idea ![]() Standoffs for the current table: ![]() Center punch every hole, all 301 of them! That's the CAD blueprint ![]() Drill ![]() Tapping with a tapmatic, thanks God my partners had this device in their arsenal of tools, all 301 holes were tapped in less than 2 hours, if you ever come across a cheap one at ebay don't let it go, this one is self reversing with torque adjust, amazing tool, really amazing! Look at the high tech torque arm support ![]() ![]() The machine I used with the tapmatic, heavy and sturdy old french iron ![]() Shimming! the drill press I have at the office does not have enough throat to make the second holes at the front standoffs. Finished! ![]() The plate is not dead flat, there is only 0.1mm (0.004") across the whole table between peaks and valleys, I can live with that, an extra standoff in the middle of the table could help improve this a little. Pablo
__________________ ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ● |
#219
| Today I finished the clamping kit for the new tooling table: ![]() ![]() And here is what I first machined with it: ![]() ![]() ![]() The hardwood is Quebracho, it has natural inner crackings, you may see them if you look closely. It's a paper weight ![]() Pablo
#220
| Added eccentric clamping tools to my arsenal ![]() Details 1/4" (6.35mm) 20tpi screws head turned to 8mm diameter Eccentricity is 1mm on the diameter Nut big hole is 8.75mm Lip hole is 6.5mm Pablo
#221
| Hello Pablo, I hope you and your family are doing well. On my side, I am now at attempt number 2 to build a router, and of course the linear rails are always a question for capability and price. On many DIY builds, people will change this part many times in order to improve it, but interestingly, you were only forced to change this part to gain more length. I worry a bit about using these high precision type rails for several reasons: - Will I be able to align them well enough using simple home methods, since they talk about machining ledges for them in the brochures - Of course the cost - Dust getting into the mechanism It seems though, that you are so far quite successful with these. Take care, Harry
__________________ Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2 |
#222
| Hi Harry, Is not that difficult, it takes some hours align everything properly, but it can be done. Aligning the rails is the easiest part IMHO then you need to align the ballscrew to the already aligned rails, thats a little more complicated, but there is a small compromise you can do, remove the back support bearing and allow a little play, the loss in precision is insignificant. Pablo
| Finding The Right Router | Crushmonkey | Commercial CNC Wood Routers | 22 | 06-19-2006 01:17 AM |
| long term stability of wood framed router | dave925 | DIY-CNC Router Table Machines | 17 | 05-05-2005 11:33 PM |
| Almost done with 1st Router project..phewww | Beezer | CNC Wood Router Project Log | 42 | 03-27-2005 05:39 PM |
| GoPackGos' 1st CNC Router | gopackgo | DIY-CNC Router Table Machines | 28 | 01-17-2005 02:35 PM |
| mhackney's 1st CNC router | mhackney | DIY-CNC Router Table Machines | 84 | 04-05-2004 08:48 PM |
