| CNC Wood Router Project Log Post your CNC machine building log here only. |
#13
"" A special Wood Welded wear-resistant finish is then applied - DURAKRYL 102. This tough, acrylic coating will repel alcohol, bleach, even paint thinner! Wood Welded Butcher Block is one of the few materials that can take so much hard wear and tear, be resurfaced or repaired without any special tools or particular skill, and come up looking as great as ever. "" I was thinking of drilling a large hole pattern in the table for workholding, and then pressing threaded metal inserts in the holes from the underside, that way they couldnt be pulled out. Has anyone done this before? |
#14
| I've experimented with inserts in a wood base and I can tell you that it just doesn't work as well as an aluminum base. After many problems with mine expanding and contracting, I finally bit the bullet and bought a 6061 base that I could tap a grid of holes into. It's a world of difference.
__________________ Proud owner of a Series II Bridgeport. |
#16
If you put a sealer on the inside of the drilled holes, though, it'd probably keep it stable. -- Chuck Knight P.S. Your machine is absolutely beautiful. |
#17
| I have a question for who can help - how do you syncronize those two axis in the case X? What kind of wiring diagram or do you use a different type of stepper driver, or you just connect in parrallel the two steppers? |
#19
But if you do decide to risk it, make sure to seal any holes you make. If the wood fibers have access to moisture, you'll eventually have expansion, albeit minimal. You mentioned using screw inserts. They do work well. They're tricky to get started and more so in a hardwood. Good luck to you. |
#20
| I too have been woodworking for over 30 years. You have several things going for you: Hard Maple is a very dense wood, the laminations of multiple slices gives a ton of strength, and makes it less apt to warp and dimensional variation. ALso the fact that it is sealed. If you put it in an enviornment that is fairly tmeperature stable and humidy stable you will help yourself. But I seriously doubt it will stay as stable as your bearings. If you want to maintain the accuracy that you have invested in your parts, slap some steel bar on the the top of the wood. Phil
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
#21
#22
And here is a link to a PDF file with full specs. I also have some Nema34 motor mounts made by THK, for KR46 actuators, they are $16 each there is also a picture of one. And if anyone is interested, I can make X-Y gantry kits to allow you to bolt three KR46 actuators together the way I did for $60. Also, what do you guys think would be a reasonable price for brackets to hold porter cable/makita, etc.. routers like the ones in the photos? Or brackets for RotoZip also. They would be precision machined from solid aluminum. I know these brackets can be tough to make if you dont have access to the proper equipment. Thanks for the complements and advise on the router table also. |
#23
| Hey all, just an update on the maple table flatness/warping concern. I ran an indicator over the whole table again, I did this also when the router new> and it is reading .02" max out of flat, the same as the first check. It has been in the garage for over 8 months now, in Houston heat/ humidity, and has shown no detectable sign of expansion or warping, so far. Unless some crazy wood warping action happens in the next 4 months, which will mark one year since the router was assembled, I would say any concern over using a laminated wood table are unfounded. It has been a VERY stable, flat and rigid surface for me in the last 8 months. I will check it again in a couple months, if it starts to show any warping, I will post it.
__________________ www.cncfusion.com CNC kits for Sieg mills and lathes |
| Help to choose CNC Router Plans. | Moondog | DIY-CNC Router Table Machines | 4 | 01-20-2010 01:50 AM |
| Techno-Isel CNC router for sale? | Noah | Commercial CNC Wood Routers | 5 | 11-27-2008 10:12 PM |
| Finished CNC router tonight | snoman70 | DIY-CNC Router Table Machines | 1 | 06-01-2005 05:34 AM |
| 2nd Generation CNC Router Design 32.5” X 14” X 6” | gregmary | DIY-CNC Router Table Machines | 9 | 03-24-2005 04:46 PM |
| buscht's cnc router | buscht | DIY-CNC Router Table Machines | 25 | 04-13-2004 11:43 AM |
