Page 16 of 18 FirstFirst ... 6131415161718 LastLast
Results 181 to 192 of 211
Like Tree1Likes
Thread: Weld Steel Green Machine
  1. #181
    May 2010
    Quote Originally Posted by CarveOne View Post
    LazyCam is a really old beta that is not supported at all. They would do newbies a great service if they removed it from Mach3. I tried it initially and only had it post one gcode properly. It's really flaky. Likewise for the free beta version of CamBam but it at least works for me in most respects. CamBam Pro is a free download with no gcode limits, but you can only run it 40 times before it breaks. It tells you each time it starts how many times you have used it. Once you open it don't close it until your gcode runs properly in Mach3. Minimizing it is ok. Mach3 will still work ok while you test the gcode in Mach3. It supports some additional features like bridges that the CamBam beta does not support.
    Post your CamBam gcode here and I'll download it and see if it looks ok on my CNC computer. Post it with a .txt filename extension so it will upload to CNC Zone ok.
    CarveOne
    ok installed plus version of CamBam and generated file still does not
    work in mach code runs but runs strange does not post image whats
    being cut in mach!
    Attached Files Attached Files
  2. #182
    Apr 2007
    Ok, I put it on a thumb drive and it's warmed up enough outside to go play in the shop awhile. Will post the results in a little bit. Sounds like you have some sort of computer/Mach3 problem. Display drivers? Don't know.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  3. #183
    Apr 2007
    Rusty,
    Your gcode looks just fine on my Win XP Pro computer and Mach3.
    Which operating system are you using? If you are using Vista, download the latest version of Mach3 if you don't already have it installed. Older versions had problems with Vista and I think it was fixed.
    CarveOne
    CarveOne
  4. #184
    May 2010
    CarveOne
    OK found a setting that seems to affect the way it looks at I J
    commands it was set to absolute changed it to Inc and the
    code seems to run correct air cutting and image displays!
  • #185
    Apr 2007
    Quote Originally Posted by R L Harris View Post
    Yeah. I forgot that one is wrong for us as it is the default.
    Let's go play....
    CarveOne
    CarveOne
  • #186
    May 2010
    Let's go play....
    CarveOne
    Well glad that was figured out my head hurting from pounding it on the work bench!!!
  • #187
    Apr 2007
    My whole head is still caved in backwards from doing that over my X and Y motors not tracking each other for 5 months or more.
    CarveOne
    CarveOne
  • #188
    May 2010
    CarveOne
    Yea these little things of setting being off can cause lot of grief
    needs to be doc that tell you if it does this check this setting ETC!
    well went bought few more bits and exestension hose for mye shop vac!
    I cut collar to fit router need to attach brushes so i can start cutting things
    with out debri going all over!
    Hey Thanks CarveOne for all your help!
  • #189
    Apr 2007
    No problem Rusty. I'm thankful for all the help I have been getting from others here. We all learn from doing our own thing and watching others doing their thing. I help others when I can.
    CarveOne
    CarveOne
  • #190
    May 2010
    OK here are shots first parts cut!
    Attached Thumbnails Attached Thumbnails Weld Steel  Green Machine-imag0016.jpg   Weld Steel  Green Machine-imag0018.jpg   Weld Steel  Green Machine-imag0014.jpg
  • #191
    Registered FandZ's Avatar
    Oct 2008
    The parts look interesting, what are they for?
  • #192
    May 2010
    Quote Originally Posted by FandZ View Post
    Bucket Arms on Toys N Joy Frontend Loader!
  • Page 16 of 18 FirstFirst ... 6131415161718 LastLast
    1. New Machine Build- Marty's Green Machine
      By MacMarty in forum CNC Wood Router Project Log
      Last Post: 02-07-2011, 08:16 PM
    2. The Chicago Electric Weld Machine is good ???
      By dumaster in forum Welding Brazing Soldering Sealing
      Last Post: 11-20-2010, 08:42 AM
    3. Job Opening Machine shop/ Maintenance Supervisor Green Bay - 115836
      By lashbeck in forum Employment Opportunity
      Last Post: 07-16-2008, 12:49 PM
    4. 1st Machine, Steel ,Overhead Gantry
      By bradodarb in forum CNC Wood Router Project Log
      Last Post: 10-18-2006, 03:05 AM
    5. new machine, aluminum or steel ?
      By max_imum2000 in forum Mechanical Calculations/Engineering Design
      Last Post: 01-27-2006, 08:29 AM
