Results 1 to 1 of 1
Thread: 5' x 10' with question on drill blocks
    Registered ktb100's Avatar
    May 2006
    Smile 5' x 10' with question on drill blocks
    Hello All,
    I am back at it again with a new build and am not clear on how I should set the programming of the drill block. I have heard many different stories and thought I would come here to clear the air so to speak.
    The drill block is shaped like the number 7. I have 8 individual spindles I am able to call down in any variation. When I ask for program examples, I find that there wasn't much consistency. I want to be able to use a "standard" post from software companies and not set it up as a "one off". Would anyone please be so kind as to share an example or two.
    Thank you very much !!
    Kirk
    Attached Thumbnails Attached Thumbnails 5' x 10' with question on drill blocks-i510db%5B1%5D.jpg
  1. spade drill flute question
    By subi4ester in forum Haas Mills
    Last Post: 05-08-2010, 10:13 AM
  2. thk blocks and rail question
    By funkenpedro in forum Linear and Rotary Motion
    Last Post: 01-29-2009, 08:16 PM
  3. Question about high-precision granite blocks
    By M30 in forum General Metalwork Discussion
    Last Post: 08-23-2007, 12:19 PM
  4. Question about this mill/drill
    By bryanrabb in forum Benchtop Machines
    Last Post: 08-23-2006, 09:09 AM
  5. To End Mill or Slot Drill, That is the question.
    By Imagineering in forum WoodWorking
    Last Post: 09-02-2005, 08:41 AM
