Oops, I almost forgot - here is a 3d file (Rhino4 *.3dm and SolidWorks *.IGES) with accurate 3d NURBS models of NEMA34 640 oz-in stepper motor together with Lovejoy spider coupling that I have measured and modeled from my existing parts. The 3d scene is set to millimeters and the IGES file can be imported into SolidWorks and many other CAD programs...
LinkBack URL
About LinkBacks
, this is my first CNC build and I just finished it yesterday (still trying to learn the Mach3 software). I don't know if I post in the proper section as my 3-axis CNC-machine is specially designed for foam art with milling cutter. However, I'm going to upgrade it with bolt-on removable hot wire that will attach to the Z-axis gantry and act like a vertical hot wire cutter through YZ-axis and XZ-axis (it will be able to rotate manually by 90 degrees around Z-axis). This should make it something like a hybrid CNC to meet my requirements.
He also completed the wiring of the stepper motors and provided me with some helpful advices about the initial setup. I greatly appreciate his help and recommend him to anyone who is going to build its own CNC-machine.
, so I will describe my problem at the bottom of my post. Any suggestions from you guys are welcome as I tried everything and still can't solve the problem by myself.
Anyway...
, so later I decided to use static chain design where both chain ends are screw-adjustable for precision control of the tension force. Since the X- and Y-axis chains are not movable (only the Z-axis uses closed chain and small tensioner gear) and lays directly on the rails, there is virtually zero backflash; not to mention the cheap maintenance cost in comparison with the lead screw design I originally planned.
