Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 03-13-2005, 12:08 AM
Clax is on a distinguished road
Large CNC Foam Cutter
I would like to know which is the bearing method and transmission of the movement (lead screw, Belt and pulley, etc.) of the large cutters as those of: Croma (www.croma-foamcutter.com), Original Foam (www.originalfoam.com) etc.
If somebody has ideas, schemes or photos in detail, would be very good because I am interested in constructing a machine of 2 by 1.80 meters.
Clax
Old 03-16-2005, 10:55 PM
bayouranch is on a distinguished road
I would also like to know
Old 03-19-2005, 01:52 AM
onthemarc is on a distinguished road
timing belt
In some of the literature I got from Hotwire direct, the bigger CNC foam cutter mentioned they used timing belts.
onthemarc
Old 03-27-2005, 09:33 AM
Mac T. Knife is on a distinguished road
I just got back from looking at the Megaplotter machines, sold by Demand Foam, and Original foam. They are using a timing belt system,,, the belt looks similar to "zip" ties. They are using steel guide rods embedded in the aluminum frame, and shielded bearings in a "V" configuration.
Old 03-27-2005, 10:45 AM
Thanks to all, any ideas how to make a automatic wire tension for diferent left and right cuts?
Old 03-27-2005, 02:27 PM
I've been wondering if a weight attched to one end of the wire would work. The weight would have to be inside some sort of tube to keep it from swinging around.
Old 09-03-2008, 01:28 AM
artsons is on a distinguished road
I want to do a foam cutter machine and been searching for too many days, cn you share your progress, plans, specific parts, etc.
thanks
Old 09-03-2008, 06:41 AM
blackbeard52 is on a distinguished road
Hope this helps....
http://www.8linx.com/cnc/video.htm
Bob
Old 01-09-2009, 08:17 PM
johnono is on a distinguished road
what sort of products are you producing?
I'm getting into large compound crown moldings, only problem is my coating.
Old 01-15-2009, 08:52 AM
cnccutter's Avatar
cnccutter is on a distinguished road
I use air cylinders to control wire tension on my machine..see pic
  #11   Ban this user!
Old 01-17-2009, 03:13 AM
damae's Avatar
damae is on a distinguished road
Nice!
How well does it work? Did you choose that method because it allow you to accommodate large changes in length? Or was there another overriding reason?
Nice aluminum welding too. Somehow I still haven't figured out how to make aluminum stick together, even though I was using a Syncrowave 250.
  #12   Ban this user!
Old 01-17-2009, 08:23 AM
cnccutter's Avatar
The main reason I went with air cylinders was to keep the same tension on the wire with different heat settings and when I'm doing a angle cut. It works great! (plus I got the cylinders out of the garbage at work) I could use longer cylinders for more angle..My buddy at work does the welding, cost me a dozen donuts...
CNC Hot wire Foam Cutter Krashlnd CNC Wire Foam Cutter Machines 7 01-16-2006 08:57 PM
Can you Convert A CNC Router to a CNC Foam Cutter with this Driver? Sanghera Xylotex 6 06-18-2005 12:19 PM
one piece foam cutter bladestalker CNC Wire Foam Cutter Machines 0 06-08-2005 07:36 PM
Stepper motor for CNC foam cutter Juancar CNC Wire Foam Cutter Machines 3 03-02-2005 01:23 AM
CNC foam cutter vcatalasan CNC Wire Foam Cutter Machines 7 04-06-2004 11:29 PM
