Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
  #13   Ban this user!
Old 01-21-2009, 02:37 AM
damae's Avatar
damae is on a distinguished road
Air Cylinders
Originally Posted by cnccutter View Post
...My buddy at work does the welding, cost me a dozen donuts...
Nice to have talented friends like that! I may think of going the air cylinder route eventually... sounds like a slick solution.
  #14   Ban this user!
Old 02-03-2009, 02:33 AM
esawyja's Avatar
esawyja is on a distinguished road
I also use the air cylinder setup, check it out at http://www.poly-cor.com
look at the CNC page
  #15   Ban this user!
Old 03-16-2009, 07:53 AM
Mcyoda is on a distinguished road
Originally Posted by Mac T. Knife View Post
I just got back from looking at the Megaplotter machines, sold by Demand Foam, and Original foam. They are using a timing belt system,,, the belt looks similar to "zip" ties. They are using steel guide rods embedded in the aluminum frame, and shielded bearings in a "V" configuration.
Can you use timing for vertical or Z-axis, will the weight of that axis push it down. Since belt has no holding torque, I was thinking is have to be screw.
  #16   Ban this user!
Old 03-16-2009, 08:00 AM
Can you share with me how the setup the air cylinder to control tension. May be a few photos. How is the tension control by the volume and pressure of the air?
  #17   Ban this user!
Old 03-16-2009, 08:08 AM
blackbeard52 is on a distinguished road
Actually the belt is controlled by probably a stepper motor which has holding torque and since there is really no weight involved in the head it shouldn't be a problem. I have seen springs used to control tension on many foam cutters.. The air cylinder idea is intriguing must be a low pressure cylinder to prevent breaking the wire at high temps.
Bob
  #18   Ban this user!
Old 03-16-2009, 08:17 AM
Bob
Bob, you are right on stepper motor when is powered there is torque but I check the Demand Products that the Large CNC is control by servo motor. I was thinking that servo motor has no torque during idle. May be I am wrong on this I haven't own servo motor.
  #19   Ban this user!
Old 03-16-2009, 08:23 AM
Yes it does....about the only difference is the control and positioning is more accurate with a servo. And more expensive.... maybe overkill for a foamy.
Bob
CNC Hot wire Foam Cutter Krashlnd CNC Wire Foam Cutter Machines 7 01-16-2006 07:57 PM
Can you Convert A CNC Router to a CNC Foam Cutter with this Driver? Sanghera Xylotex 6 06-18-2005 11:19 AM
one piece foam cutter bladestalker CNC Wire Foam Cutter Machines 0 06-08-2005 06:36 PM
Stepper motor for CNC foam cutter Juancar CNC Wire Foam Cutter Machines 3 03-02-2005 12:23 AM
CNC foam cutter vcatalasan CNC Wire Foam Cutter Machines 7 04-06-2004 10:29 PM
