Results 1 to 2 of 2
Thread: mm2001 + GMFC = Steppers run very, very slow
    Jul 2009
    Netherlands
    Exclamation mm2001 + GMFC = Steppers run very, very slow
    Hi guys,
    Just finished the mm2001 board and did some test runs with GMFC.
    Result: Stepper motors run really, really slow. One rotation takes six seconds! I'm using 1.8deg/step motors.
    I am not using the zener diodes yet, does this make a huge difference? Or could this be a software issue?
    Hope someone can help me out here, this way it would take days to cut one piece of foam.
    Jul 2009
    Netherlands
    Seems like a software problem. Steppers run way faster (one rotation per sec to 1.5 rotation per sec) using FoamWorks.
    However, my driver chips run hot because of current flowing while steppers are not rotating. I'll post a dedicated message on that problem.
  1. Help! - MM2001 & GMFC motor movement
    By DreamerM in forum Foam Cutting Software
    Last Post: 10-09-2008, 11:06 AM
  2. mm2001 board
    By Scott Lister in forum CNC Wire Foam Cutter Machines
    Last Post: 09-19-2007, 06:47 AM
  3. GMFC help needed
    By gguidi in forum CNC Wire Foam Cutter Machines
    Last Post: 07-25-2007, 08:03 PM
  4. Help on programing the PIC in MM2001
    By DreamerM in forum General Electronics Discussion
    Last Post: 03-18-2007, 06:22 AM
  5. MM2001 v0.62
    By JerryFlyGuy in forum CNC Wire Foam Cutter Machines
    Last Post: 12-06-2005, 08:18 PM
