Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 03-01-2005, 11:33 AM
Juancar's Avatar
Juancar is on a distinguished road
Stepper motor for CNC foam cutter
Hi mates:
I'm planning to build a CNC foam cutter similate to this:
http://www.8linx.com/cnc/
But i'm very confused with the torque of the stepper motors: I will use unipolar motors, and I'd like to know wich torque should i choose. 30 oz/in is enough, do i need a 100oz motor or higher??
Thanks.
Old 03-01-2005, 12:42 PM
buscht's Avatar
buscht is on a distinguished road
I noticed that these guys are selling small 40oz/in motors for foam cutting. There must not be much force required to move the wire through the foam.
My only thought is that you can get 100 oz/in motors pretty cheap so why not get the extra power?
Old 03-01-2005, 01:25 PM
*Registered*
HobbyCNC is on a distinguished road
Actually. the wire never touches the foam so zero cutting load. 30oz-in would be bare minimum. 100oz-in for heavier commercial production machines. 50-60oz-in for the lighter duty hobby type machines is fine.
Dave Rigotti
www.hobbycnc.com
Old 03-02-2005, 01:23 AM
Hobbiest is on a distinguished road
I have read that with hot wire foam you want to use the slowest speed, and lowest temp for the wire. Just 2 cents.
Stop talking about it and do it already!!!!!
CNC Hot wire Foam Cutter Krashlnd CNC Wire Foam Cutter Machines 7 01-16-2006 08:57 PM
Can you Convert A CNC Router to a CNC Foam Cutter with this Driver? Sanghera Xylotex 6 06-18-2005 12:19 PM
one piece foam cutter bladestalker CNC Wire Foam Cutter Machines 0 06-08-2005 07:36 PM
Using a controller and motors from a foam cutter Quicker DIY-CNC Router Table Machines 3 04-08-2005 05:06 PM
Good Foam Cutter CAM Software? vacpress General CAM Discussion 0 03-30-2004 06:26 PM
