Results 1 to 7 of 7
Thread: hotwire controller diy
    Apr 2006
    na
    need a simple but effective controller for my hotwire
    looking for plans and info for diy unit
    need a current /tempture controller
    please post info pic etc
    Gold Member
    Oct 2004
    Attached Thumbnails Attached Thumbnails hotwire controller diy-foam_cutter_circuit.jpg
    Apr 2006
    na
    Quote Originally Posted by CJL5585 View Post
    can you explain how the triac works, not sure if it will modulate the temp
    or regulate it?... i think it may be like a light dimmer idea, with no feedback
    to regulate the temp is just a simple current limiting circuit... looking for a pwm or modulating circuit to cool the wire when light cuts are made
    and when temp is dropping increase current automaticly...
    Gold Member
    Oct 2004
    Quote Originally Posted by eloid View Post
    What if the temperature was controlled by modulating the positive portion of the secondary transformer AC voltage 60 times per second?
    Well, that is the way it works. The variable potentiometer setting (which is controlled by the operator, and who determines the cutting wire temp) completes the circuit.
    The pot setting and cap create a variable charge time which determines how long the triac conducts current during the positive portion of the AC sine wave. During the negative portion of the AC sine wave, the triac is switched off. Since the sine wave is a 60 hertz signal, the control voltage, and also the current to the cutting wire is turned on and off 60 times per second. Changing the pot setting will increase or decrease the amount of time the triac conducts, thus increasing or decreasing the temp.
    If you are looking for a temperature controlled, closed loop controller, then it would probably be best to purchase one. This circuit could probably be modified to use a thermistor for temperature control, but would require some additional design.
    Gold Member
    Oct 2004
    Link to controllers, wire, handles, etc
    https://www.abbeon.com/store/item.cfm?code=1950
    These units are represenative of the circuit I submitted to you. They DO NOT have internal temperature control, but cost hundreds of dollars.
    Apr 2006
    na
    I have been looking for pwm module, that whould allow the user set the desired current, and freq as needed. As the out of the pwm would sence the current, it would change the frequence and duty cycle thus changing and maintaining the current output as load and cut is occuring. the duty cyle would be auto adjusting for the desired current / temperture.
    Gold Member
    Oct 2004
    I do not have any knowledge of any manufacturer who makes such a unit.
    1. hotwire an AC servo
      By Karl_T in forum Servo Motors and Drives
      Last Post: 05-03-2009, 01:14 PM
    2. Need used hotwire CNC for EPS foam
      By dizzywizzy in forum Want To Buy...Need help!
      Last Post: 02-22-2009, 08:43 PM
    3. Which hotwire machine to buy
      Last Post: 04-21-2008, 04:05 PM
    4. I'm looking to job hotwire work out
      By decor designer in forum CNC Wire Foam Cutter Machines
      Last Post: 07-29-2007, 09:03 PM
    5. I'm looking to job hotwire work out
      By decor designer in forum Employment Opportunity
      Last Post: 08-21-2006, 09:05 PM
