Results 1 to 6 of 6
Thread: Software for cutter
    May 2009
    Spain
    Software for cutter
    Hello,
    I wish to know which software you work for the foam cutter.
    I know CENECE but I like to try other alternatives.
    thanks.
    May 2009
    I use Croma software with Corel Draw X
    Registered Tsooko's Avatar
    Mar 2009
    form cutting software
    Hi.
    Go to HTTP:// WWW. FoamWork. net
    $50.00
    can get a cad progam for the same price
    I haven't used it but it looks good.
    Luck
    Ted
    If you are going to be a Bear...Be a Grizzly!
    Feb 2005
    South Africa
    Hi All,
    Have you looked at www.profili2.com ?
    Jun 2009
    new york
    I am always use a hot wire for foam cutter.
    Sewing Machines
    Registered Kroko's Avatar
    Apr 2009
    Slovenia
    Check out my CNC hot wire foam cutter. It is controlled with CNC USB motion controller which directly supports Profili generated 4-axis g-code as well as other g-code. For 4-axis foam cutting select "Foam" settings and name your axes XY and UV in g-code.
    1. Software for laser cutter
      By Morwim in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 05-23-2011, 06:38 AM
    2. Another new free wire foam cutter software
      By SteveC68 in forum Foam Cutting Software
      Last Post: 11-07-2009, 01:09 AM
    3. Hot-Wire Cutter Software
      By Alonson in forum Foam Cutting Software
      Last Post: 04-14-2008, 01:52 PM
    4. Newbie looking for 2-D pattern cutter software.
      By amccoy in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-01-2006, 02:05 PM
    5. Good Foam Cutter CAM Software?
      By vacpress in forum General CAM Discussion
      Last Post: 03-30-2004, 06:26 PM
