Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 02-12-2009, 05:13 PM
DanOSB is on a distinguished road
power supply size? for multi wire (total 250 inches of wire)
i want to do 5 wire setup and the wire legnth is aprox 50 inch each..
i want to know what size power supply i would need
i have been reading few different sites and some say only need ac power supply and others say dc power supply..
which should i use?
Cheers
Dan
Old 02-22-2009, 09:45 PM
i got a solution..
what you need is variable voltage transformer (it will output basically 0 to 100 percent of your input of vac power)
the material i used is Variable Autotransformer directly connected from 120 vac and on the output there is a fuse before it connects to hot wire
its very simple and cheap solution but if you are only running one wire in shorter distance this item doesnt control fine adjustment so it might be harder to adjust..
hope this answer helps if someone else is trying to do this..
Cheers
Dan
Old 02-27-2009, 11:44 PM
Mcyoda is on a distinguished road
Insulation of the hot wire
Hi Dan,
How do you attach the wire to the machine and how you insulate the hot wire from it. It sound a little scary for me.
I need to find a solution or build one for around 80 feet of wire. What do you recommend since you have more information about the power supply.
thanks
Old 02-28-2009, 04:23 AM
i insulate it from the machine by having my wire connectors all mounted to acrylic peice so its not conductable
possitive on one side and negative on other side and all wires are going thru both sides
hope im clear..
Cheers
Dan
Old 02-28-2009, 05:03 PM
hope im clear..
Cheers
Dan
That is very good idea but will the hot wire burn the acrylic piece?
Old 03-02-2009, 04:34 PM
well what i have is 30 inches long alumimum plate and that plate is adjustable for 5 wire setup and that alumimum plate is bolted on to acyrlic so there is no heat on that alumimum plate since all of the heat goes to the wire
hope this part is clear..
Cheers
How to wire an 8 wire stepper motor technosteve DIY-CNC Router Table Machines 1 01-16-2009 05:01 PM
Need a little help? with 8 wire stepper motors total newbie stevef12005 Stepper Motors and Drives 1 12-18-2008 06:08 AM
Recommended wire size for hookup sonex128 Automation Technology Products 1 02-29-2008 02:17 PM
Servo power and encoder wire interference? klxrcr Servo Motors and Drives 2 01-15-2008 11:14 PM
Hookup wire size Monte Xylotex 0 02-20-2005 03:52 PM
