Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 02-06-2009, 12:07 AM
DanOSB is on a distinguished road
Need suggestion what software or cam or ??? to use with lathe/turntable
I'm retrofitting a croma 4x8x4 hot knife cnc and im going to add lathe (5th axis) while im retrofitting it and using g540 from geckodrive (parallel port)
i dont mind using mach or something but i would need some decent software to be able to produce gcode or a foam cutting software that will work with parallel port
Any suggestion or input would be appreciated
Dan Braun
Old 02-06-2009, 12:21 AM
harley4ever is on a distinguished road
Try Dolphin cad cam. Ive been using for quite some time now and have nothing but good things to say about it. Another suggestion is surfcam but that can be very costly.
Old 02-06-2009, 12:40 AM
okay will look into it.. (i rather mach myself since its very nice controller software)
thanks for quick reply.. if anyone else has other suggestion im still open to options
Cheers
Dan
Old 02-06-2009, 12:44 AM
Mach 3 is a controller software. It is not cad cam.
Old 02-06-2009, 12:49 AM
i know that mach is controller software(using it for my cnc router) love all of the options/features that mach can support.. but for hot wire foam cutting is a whole new world for me i have no experience on it.. i can build the table to make it move where i want it to move but for designing part i have no idea (im a 2.5 d guy and want to make bottles or columns or bunch round parts out of cnc foam cutter
Cheers
Dan
turntable for welding DanOSB General Metalwork Discussion 8 07-20-2009 09:18 PM
Need Help!- connecting turntable pedroenrique CNC Wire Foam Cutter Machines 0 11-30-2008 05:17 PM
Cam software suggestion fidia General CNC (Mill and Lathe) Control Software (NC) 0 12-09-2007 09:56 AM
Hello, I need suggestion on getting 4 axis CNC as well as software to do few things. jinu117 Benchtop Machines 17 07-16-2006 05:40 AM
help with turntable tallwelder Welding, Brazing, Soldering, Sealing 4 05-19-2006 02:12 PM
