Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 01-17-2009, 02:36 AM
damae's Avatar
damae is on a distinguished road
Hot Pin Foam Cutter
Something common to hotwire cutters:
1. It is complicated to cut an inner hole without leaving an enter/exit path.
2. CAM software rarely understands that there is no "safe Z" for rapids.
How about solving that problem by using a 1mm diameter "hot pin" that is supported only from one side? With a solenoid to retract the pin to a "safe z", you could allow the cam software to use rapids carelessly and cut interior shapes.
What I propose might only be applicable to the type of 2-axis foam cutter I built.
What do you guys think? Is it feasible? How small of a diameter pin could I get away with? 1mm? 0.5mm if moving really slowly?
Old 01-21-2009, 03:20 PM
voltsandbolts's Avatar
voltsandbolts is on a distinguished road
Interesting idea, Id like to see how it comes out, and what size pin you need for reasonable results.
Good luck.
Rob.
Deeds not words...
VoltsAndBolts Alternative Power Forums http://www.voltsandboltsonline.com/
Old 01-21-2009, 05:18 PM
vlmarshall's Avatar
vlmarshall is on a distinguished road
I wonder if heating it evenly will be a problem. It seems like the far end would be a lot cooler, resulting in tapered cuts or limited usable depth.
Good luck, I'm looking forward to your tests!
Old 01-24-2009, 07:40 PM
damae's Avatar
Even heating
Good point about the challenge of heating evenly.
Perhaps I can use a copper pin instead of steel for better heat conduction.
Maybe the best thing to do is simply test it. I am having fun with the hotwire cutter for now, but eventually I'll give it a go.
Need Help!- CNC foam cutter located in UK chris_bean CNC Wire Foam Cutter Machines 2 08-30-2008 11:43 AM
Simple foam cutter venomx999 CNC Wire Foam Cutter Machines 1 02-14-2007 11:20 PM
My first CNC! soon to be foam cutter nikolatesla20 CNC Wire Foam Cutter Machines 8 08-06-2005 01:48 PM
CNC foam cutter vcatalasan CNC Wire Foam Cutter Machines 7 04-06-2004 10:29 PM
Foam cutter paulried CNC Wire Foam Cutter Machines 4 10-30-2003 03:58 PM
