After many, many searches with Google, Bing, Altavista, I have not been able to locate George Barlow, TSI or Foamline software.
Does anyone have any recent contact information?
Thanks,
Jim
Greetings,
First post, but I have spent a few months looking through the forum for an answer, but had not found one for my question.
I have a large 2 axis foam cutting machine; will cut 12’W x 8’D x 5’H Blocks. I am trying to replace the front end, as the computer (MAC) and software are from 1995, and I find the software somewhat limited. I can program in X,Y fine (cut boxes), I can also import a PIC file to display on screen and trace it, (a royal pain), and the program has only one font. I need to be able to import Illustrator vector files and create custom signs from the hundreds of fonts out in public domain.
What I have is as follows:
• T.S.I. Inc. Foam Cutting Machine (I believe they are out of business)
• Steppers on the machine (1-X, 1-Y) are: SloSyn M093-FD11G12 2400 Steps/Rev (I forget the voltage)
• Stepper Drive unit: ROF 5004 (River Oaks Farm, Austin, TX, I believe they are out of business)
• Software: Foamline 5000 on license from George Barlow, I believe he is out of business)
This runs of a MAC Performa 6360 and output is from the Modem (serial) port on the MAC.
Stepper Control works fine and I have already repaired once and have extra components on hand for that.
If I were trying to replace an old PC and software running off the printer port, I think it would be a piece of cake, but the stepper controller looking for a serial input makes my quest a little difficult.
Happy New Year,
Jim
Thanks,
Jim
hi hover1,
sorry my english; i read your post and i suggest you this points:
1) if you want to recycle you electronics you must use only the stepper driver; in this case you have to buy only the LPT breakboard to connect with a normal IBM/PC. For run the machine you need CNC control program like Mach3 or DeskCNC (this depend you use 4 indipendent axis or not)
2) you recycle only the stepper motor and buy a new complete control box and use Mach3 or deskcnc for run it
I hope to help you
bye
Romano from Italy
P.S. This is my DIY machine : my hotwire cnc machine from Italy :-)
