Results 1 to 3 of 3
Thread: Foam blank question on difficult wing
    Aug 2008
    I am having one hell of a time figuring out the foam blank for my wing, the wing has a 55deg sweep at the leading edge and a 17deg sweep at the trailing edge, my root chord is 18.40" and my tip chord is 3.61". Total width of the wing panel for one side is 13".
    The foamworks software tells me that I need a block 10.5"x 28.0", it looks like they are asking me to place the block at a angle but I cant seem to get that figured out, all cuts so far have come way off and due to the small tip chord, the machine runs very slow at the tip resulting in a trashed piece along with wrong sweep angles.
    I need help please!
    I am hoping somebody has a simple answer but I am sure it is not given the hassle this machine has been from day one.
    If anybody can help it would be greatly appreciated.
    Thanks in advance,
    Chris
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    I'd bet given the planform - you'd have a tough time even with a hand operated BOW! Such a short tip cord relative to the root--you may have reached the limits for hot wireing. Have you seen any similar DELTAs/near-deltas that have been hotwired?
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Aug 2008
    Quote Originally Posted by High Seas View Post
    Sure have. I guess I will just mill it....
    I figured this was the problem but I was in denial. Thank you for the reply!
    Chris
  1. CNC Foam cutter for RC plan wing
    By jc de campo in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2008, 07:21 AM
  2. CNC foam wing cutters in the classroom
    By charper in forum Teachers Hang out
    Last Post: 11-06-2006, 02:59 AM
  3. RFQ - Need a prototype foam wing core cut
    By Quicker in forum Employment Opportunity
    Last Post: 08-01-2006, 04:26 PM
  4. Larger Surfboard Blank foam Composite Plug cutter
    By Latexgurl in forum CNC Wire Foam Cutter Machines
    Last Post: 07-12-2005, 01:49 PM
  5. Question about cutting balsa wing ribs
    By Heliboy247 in forum Parts for Radio Control Models
    Last Post: 05-28-2003, 07:11 PM
