Results 1 to 5 of 5
Thread: Can any suggest
    Site Owner CNCadmin's Avatar
    Mar 2003
    Can any suggest
    a good CNC foam cutter machine for cuting foam wings?
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Apr 2003
    Here is what I think is a well thought out and executed wire cutter. Including instructions on how to make it:
    http://www.8linx.com/cnc/cnc.htm
    Chris
    Apr 2003
    More Links-
    LiftZone article:
    http://rcgroups.com/links/index.php?...at=240&id=4103
    Ready assembled machine:
    http://www.foamlinx.com/
    Four axis controller. In FrenchI haven't tried it)
    http://www.teaser.fr/~abrea/cncnet/e...2001/mmx.phtml
    Cheers,
    Chris
    Apr 2003
    Hi CNCadmin,
    l bought one of the complete kits from Tal at foamlinx.com. Spent a couple of evenings putting it together and works well straight out of the box.
    Still learning the software and trying to increase the speed of the cuts but would recommend it, if you haven't time to put one together yourself.
    Here's a couple of extra links
    www.cenece.com (Spanish site you may need to translate it)
    http://www.hobbycnc.com/exppackage.htm
    http://www.het-holland.nl/
    http://www.modelltechnik-jung.de/cnc/styro1.htm
    Cheers
    Fran
    Gold Member RCjunkie's Avatar
    Apr 2003
    CNC Foam Cutter
    Hi
    I'm running a FoamLinx.
    Foam Linx
    With the Muller software, and trying out Foam Works
    2 wrongs don't make a right
    But 2 Wrights makes a Airplane
    Kevin Matney
    www.Matneymodels.com
    734 - 848 - 8195
    "IN GOD WE 'TRUST "
  • Posting Permissions
