Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 05-27-2008, 05:16 PM
DaniSaez is on a distinguished road
New release CeNeCe PRO 1.11
New release of CeNeCe PRO ver.: 1.11
Hi everyone,
Just to let you know, that the new release 1.11 of the CeNeCe PRO, is available.
WHAT'S NEW:
* Added support for Autocad versions: 2000, 2002, 2004, 2005, 2006, 2007 and 2008
* Added new wizard to directly cut coordinates files (DXF,PLT,DAT,etc..), without having to add the file to the program or creting a new project, simply using the default setup values.
* Improved loading performance and shape conections specially in DXFs files.
* Corrected error in cutting speed in X movement; in some cases, cutting speed was reduced significantly at the begining and end of the cuts.
* Improved performance during the cut process.
* Improved overall performance of the program.
* Added checkbox to activate/deactivate progress bar during the cut, usefull for slow computers.
* Improved upgraded the import of shapes from sizes now up to 1.000.000 mm.
* Improved performance of 3D simulation of kits.
* Corrected error in cut time calculation
* Corrected points and syncs number with multpile CreaDat screens
Don't forget to visit our forum at http://foro.cenece.com, although it is mainly in spanish you're all welcome!
Best regards,
Javier López y Dani Sáez / Dani Sáez y Javier López
http://www.cenece.com - CeNeCe official site
http://foro.cenece.com - CeNeCe official Forum
pedidospro@cenece.com - Orders and license management
pro@cenece.com - Technical Support
New release CeNeCe PRO 1.11 DaniSaez Foam Cutting Software 4 08-30-2008 01:35 PM
New release of CeNeCe PRO ver.: 1.10 DaniSaez Foam Cutting Software 12 07-17-2008 08:40 AM
New release of CeNeCe PRO 1.07 DaniSaez CNC Wire Foam Cutter Machines 0 11-20-2006 04:49 PM
New CeNeCe PRO 1.06! DaniSaez CNC Wire Foam Cutter Machines 0 03-02-2006 04:24 PM
