Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 03-04-2008, 04:20 AM
GEFR is on a distinguished road
Kerf on Foamworks
Apparently this question is already on here somewhere but I can't find it. However: I am using Foamworks and whatever I put into the "Kerf" dimention box not much seems to happen. Being stupid I thought if I entered 10 mm then assuming a wire of no thickness at all (stick with it!) The software would add 5mm all round my shape. Or maybe just 5mm. This doesn't happen so either I have got it all wrong or my software ain't working right.
Regards
Old 04-01-2008, 03:35 AM
GAWnCA's Avatar
GAWnCA is on a distinguished road
I bought Foamworks and to this day I have yet to get it to cut just what I need it to cut and be clean about it. I also bought MACH 3 and have yet to fire anything up using it. I need to learn CAD first. What are you trying to cut?
Old 04-02-2008, 02:56 AM
I pull DXF files into Cadworks then process them into DAT files which can be made into cut files on foamworks. Foamworks will not work unless both DAT files have the same number of entities/lines. I sometimes build complex shapes by drawing in coordinate using the keyboard rather than the mouse in Autocad then exporting the them as Autocad DXF files which can be read bt cadworks. After an initial struggle I am finding Cadworks pretty good although not very intuitive. I am very successfully cutting Blue foam - Dow Floormate in 2400 X 600 X 80. I run about 2A through Nichrome wire at 3Kg tension at between 1 and 1.4 mm/sec. To set the wire temp (current) I place a piece of foam on the wire and set the current so that the weight does the trick. I am driving four steppers X1Y1, X2Y2 via a Hobbycnc driver board and a 24V 10A DC power supply. My big challenge is to creat cut files which will deal with large delta aircraft wings wihout excessive melting at the tip due to slow cut speed in relation to the correct speed at the root. (in any tapered or conical cut the cut speed can only be ideal at one position along the wire) I need suggestions as to a free download (trial) for XYZ software as my machine is reconfigurable to three axis. Tell me exactly how you are trying to use foamworks. Incidentally I am informed that the kerf feature is problematic and will be removed. Hope this helps.
Cheers
Ken
PS Nice boat. I have a 14' Aluminum ski boat with a Ford Mexico rally car engine. It does 40MPH and spends most of the time airborn!
How to detect Kerf Crossing ? [ THC PLASMA ] MaXx General Electronics Discussion 1 12-02-2008 03:54 AM
Foamworks gar General CAM Discussion 1 11-29-2007 02:15 AM
Foamworks ver.3 vulcom1 Foam Cutting Software 0 06-17-2007 01:08 PM
plasma kerf sluggo CNC Plasma and Waterjet Machines 8 03-12-2007 05:53 PM
FoamWorks 2.1 and DXF2DAT 3.0 software djmrozin Product Announcements & Manufacturer News 0 02-15-2004 09:35 PM
