| CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..) |
| CNC foam cutter Here is one I built about 6 months ago. I use the 8linx board. I updated the motors to 100oz and got more speed on a 3/8-16 rods on my X-axis and used ACME 3/8-10 for the Y-axis. Both axis operate about 3mm/s and its fast enough. Got most of my information from the French sites and tables already built. I did not want to have to build a 6" box platform so I made some modifications. This cost me about $200 for the electronics and another $250 on linear bearings and shafts. The rest of the parts I made from plastic (cutting board) and wood as I do not have access to a milling machine. Vic
__________________ www.VicRC.com |
| Looks Nice! Do you have any pictures of things you've made with it?
__________________ My name is Electric Nachos. Sorry to impose, but I am the ocean. http://www.bryanpryor.com (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| pictures I do have some sample cuts located on my web and more pictures of my machine at http://www.vicrc.com/cnc/cncfoam.htm Also made some horizontal foam filler for my P38 fiberglass fuse and was extremely happy with the combination of strength and light weight. http://www.vicrc.com/P38-5.htm you can't see the blue foam filler on the horizontal stab, but its there. Recently cut panel cores for filler for my outer panel molds, will take some pics tonight and post. Vic Happy cutting and flying!!! Somehow 'building' gets in the way of both
| Sample cuts! Here is a sample cut. The cores are filler into my outer panel molds. Vic
| This is what the panel looks like after laying up the part Vic
| I am using the Gilles Muller software, I think its $35 you can get it at http://gm.cnc.free.fr/index_en.html Vic
| Try this out
__________________ 2 wrongs don't make a right But 2 Wrights makes a Airplane Kevin Matney www.Matneymodels.com 734 - 848 - 8195 "IN GOD WE 'TRUST " (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Large CNC Foam Cutter | Clax | CNC Wire Foam Cutter Machines | 18 | 03-16-2009 09:23 AM |
| CNC Hot wire Foam Cutter | Krashlnd | CNC Wire Foam Cutter Machines | 7 | 01-16-2006 08:57 PM |
| Can you Convert A CNC Router to a CNC Foam Cutter with this Driver? | Sanghera | Xylotex | 6 | 06-18-2005 12:19 PM |
| one piece foam cutter | bladestalker | CNC Wire Foam Cutter Machines | 0 | 06-08-2005 07:36 PM |
| Stepper motor for CNC foam cutter | Juancar | CNC Wire Foam Cutter Machines | 3 | 03-02-2005 01:23 AM |
