Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Power Supply for foam cutting
    Nov 2004
    I have wire for foam cutting:
    Nickel-Chrom 0,2mm/0,008inch resistance on one meter is 16,8 ohm
    Nickel-Chrom-Titan 0,4mm/0,016inch resistance on one meter is 8 ohm
    How to calculate what kaind voltage and ampere I need if I use 1 meter of wire.
    Does anybody have schematic for foam cutting.
    Aug 2005
    knoxville,usa
    power supply
    Sep 2006
    I built that power supply about 2 months ago and it cannot be done for the $30 that the author claims. A few of the parts are no longer available at Radio Shack. Also the transformer listed is only good for 2 amps. I have this supply connected to a 24" bow with .018" stainless nichrome wire. With the supply set to the hottest setting it still has a lot of drag through the foam. It would work for extremely slow cutting speeds at best. How much money are you willing to spend on a power supply?
    Also are you going to be using this with a CNC machine? If so are you planning on using GMFC or Jedicut (both of which have heat control from a DC power supply)?
    Steve
    Nov 2004
    For now without cnc only testing wire and building proper power supply. So do you plane to build some other power supply.
    Sep 2006
    I plan on buying a power supply already built. You can get an excellent power supply on ebay. Just search for Mastech power supply. You need at least 5 amps. If you want to build a good power supply then you will end up spending close to 3/4 of the cost of the one you can buy on ebay with almost none of the features. When I built my supply I bought most everything from mouser, and a local store. I ended up with over $50 in receipts, and a power supply that isn't that great.
    S.N.A.F.U. miljnor's Avatar
    Jan 2005
    The trick with building your own power supply is scavenging used sources!
    Otherwise your ARE better buy a pre-made because Steve is right the parts cost is close to a pre-made with a lot less features and not pretty besides.
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Nov 2004
    I am researching on web power supply for foam cutting. Problem is electronics - potentiometer, transformer is not a problem I have couple of them witt different voltage and ampere.
    Sep 2006
    Try the power supplies on this page.
    http://users.belgacom.net/hamradio/homebrew.htm
    There is an 18V 4 amp DC supply that looks pretty easy to build. You have to scroll down on the left side of the page to get to the Power supply schematics.
    Jan 2005
    Did the sight get hacked?
    this is the only forum i could post in?????
    thanks
    Michael T.
    Aug 2005
    knoxville,usa
    power supply
    Havent ordered from here yet but prices are unbelivable even if they are kits
    http://www.anykits.com/catalog/
    Bob
    Aug 2005
    knoxville,usa
    power supply
    A very good conversion of PC PSU..... http://www.antennex.com/preview/archive3/powers.htm
    bob
    Sep 2006
    How about these Power Supplies? Only problem is they are non adjustable output. However if you run a board with heat control like the HobbyCNC Foam Pro or the MM2001 and use either GMFC or Jedicut then these power supplies would work as the board and software control the wire heat using pulse width modulation I believe.
    http://www.mpja.com/prodinfo.asp?number=16013+PS
    Steve
  • Page 1 of 2 12 LastLast
    1. Foam Cutting Power Supply Questions - Non CNC
      By 11bravo in forum CNC Wire Foam Cutter Machines
      Last Post: 04-29-2007, 12:33 PM
    2. Foam cutter Power supply
      By wdp67 in forum CNC Wire Foam Cutter Machines
      Last Post: 01-15-2006, 01:27 AM
    3. Power Supply from a computer power supply
      By jmytyk in forum General Electronics Discussion
      Last Post: 01-11-2006, 03:56 PM
    4. Need help with foam cutting
      By Spitfire in forum CNC Wire Foam Cutter Machines
      Last Post: 09-07-2005, 12:31 PM
    5. CNC Foam cutting HELP!!!
      By Flight in forum General Electronics Discussion
      Last Post: 10-27-2003, 08:24 PM
