Results 1 to 4 of 4
Thread: Foam plug layering software?
    Sep 2006
    Hello all, long time lurker, first post.
    I have long built foam plugs for fiberglass bodies by laminating numerous layers of 1-2" thick foam sheets roughly cut to my desired shape and then sanding. What I did not like about this method is that it's precision was based on my eyeball. I am investing soon into a CNC plasma/multipurpose table and have heard of programs that allow you to develop cross sectional templates of your 3d object. I am seeking to implement something like this on my CNC table but am clueless as to what program(s) will allow me to do this. I am making the transition from freehand design to Cad but will any cad program (AutoCad, Rhinoceros) allow me to divide the object into cross sections with thickness of my foam sheets? I am hoping to cut these templates on my CNC table.
    Thanks for any info or insight that anyone might have.
    Mar 2003
    Shelby Twp, MI....USA
    Yes, you can slice an object up in most CAD programs, but there's no automatic button to do it. How the object is created will dictate how you need to slice it. There's an easier way, though.
    Both MeshCAM and Cut3D will automatically create slices of your models and create the code to machine the individual slices.
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    if you dont have MESHCAM, and if you don't mind saving your cad output as stl - stereolithography -- then use STLWORK from IMSERV. It does slabbing - just select it and its done automatically and generates the gcode. Was pretty economical as I recall.
    Not with the company - just like the gear.
    cheers - JIM
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Sep 2006
    I am much obliged for your quick replies. These are some very interesting suggestions that I will investigate further. Thank you.
  1. Seeking someone to cut foam plug
    By skewzme in forum CNC Wire Foam Cutter Machines
    Last Post: 01-10-2011, 01:47 PM
  2. MDF Layering with Glue?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 10-16-2006, 05:40 PM
  3. Step-four foam cutters, software?
    By MAF KITS in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2006, 04:24 PM
  4. Larger Surfboard Blank foam Composite Plug cutter
    By Latexgurl in forum CNC Wire Foam Cutter Machines
    Last Post: 07-12-2005, 01:49 PM
  5. Good Foam Cutter CAM Software?
    By vacpress in forum General CAM Discussion
    Last Post: 03-30-2004, 06:26 PM
