| CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..) |
hi, I´m begining a small bussiness, I´m making crown molding for arquitectural decoration , I´m using xps foam 16 kg/m3, the problem is that the cuts are not straight, the profile and surface are very good, but some cuts are not. I´m using cnc at 20 in/min, and the cut lenght is 4 ft, this machine is home built, I have a foamlinx 3920foam cutter, but the problem is the same. I think that the problem is the internal stress of the foam, but I´m not sure and I don´t know what can I do, could some one help me please?. thankyou |
| Hi - any chance you can post a picture of what you are seeing ? There definitely is internal stress in some foams. I have seen foam being marketed as "stress relieved" - probably some kind of heat treatment prior to cnc work. |
| thank you for your help Harryn, unfortunatly my digital camera is not working, but the center of my molding has a curve about 1/8 inch separate of the straight line, The material is expanded polystyrene(eps), and sure you are right, the problem is internal stress because the corners are perfect whitout deformation. I will try to get information about internal stress, and foam stress relieved, thank you. |
| Has anyone used crown rollers? | jerchi | DIY-CNC Router Table Machines | 1 | 10-19-2007 08:54 AM |
| Trouble creating toolpaths for Crown | robinsoncr | MadCAM | 16 | 07-27-2007 09:06 PM |
| Need a straight answer... | WilliamD | Mach Software (ArtSoft software) | 3 | 09-14-2006 05:18 PM |
| Need Cad/cam Software for designing Crown Wheel | nessei | Mechanical Calculations/Engineering Design | 0 | 08-01-2006 08:52 AM |
| a head + crown | D5zUga | Rhino 3D | 0 | 01-21-2005 01:36 AM |
