Results 1 to 3 of 3
Thread: mm2001 board
    Apr 2005
    mm2001 board
    Where are you guys getting the printed pcb boards? I really don't want to try to etch the board myself. If anyone has one for sale I would be interested.
    Scott
    Apr 2005
    I was going to make the board also but had the same problem and also checked the parts cost. Unless you want to do it for the heck of it I went with the Hobbycnc board. It was a good price and compatible with the programs. Dave helped me also on his forum which also helps.
    John
    Apr 2005
    vulcom1, Thanks for the info, I will check into that option.
    Scott
  1. Help on programing the PIC in MM2001
    By DreamerM in forum PIC Programing / Design
    Last Post: 08-29-2011, 08:56 PM
  2. Help on programing the PIC in MM2001
    By DreamerM in forum CNC Wire Foam Cutter Machines
    Last Post: 06-01-2007, 05:15 AM
  3. Help on programing the PIC in MM2001
    By DreamerM in forum General Electronics Discussion
    Last Post: 03-18-2007, 06:22 AM
  4. MM2001 reset (or not...)
    By Jalex in forum CNC Wire Foam Cutter Machines
    Last Post: 04-29-2006, 12:20 PM
  5. MM2001 v0.62
    By JerryFlyGuy in forum CNC Wire Foam Cutter Machines
    Last Post: 12-06-2005, 08:18 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
