Results 1 to 4 of 4
Thread: 4 or 5 Axis?
    Aug 2007
    4 or 5 Axis?
    Ok guys,
    I want to build a machine to make 3d models of cars, rockets and the like. Now 3 axis just won't cut it. can I do it with 4 axis or do I need to go with 5 axis and 4,5 axis being the cutter arm? if so do I just use the 3 axis plans I have and modify the cutter arm to allow the other two axis. I only purchased my plans on Sat from Rockcliff and I'm kinda lost. any help would be appreciated especially if you have plans for a 5 axis router. I want to cut from foam, plastic and light density wood. I will be buying my motors and controller from Hobby CNC as they're the cheapest that I can find.
    Gerald
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Sounds like you have a 3 axis up and running? You could try and make a go of it by doing the left side then right side separate. Then assemble the 2 halves. Most cars and rockets have some undercuts from that side view - but you could work that out too. You could prove that real quickly in CAD for the first project.
    There is a good site shopwing using Globe Motor rotary table bits for a 4 and 5 axis build. Rainner (my bad spelling -- he does a lot of Keltic knots etc -- based in Scotland I recall) - could search here or google to get a good idea
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Jun 2003
    http://www.rainnea.com/cnc_5axis.htm is the site High Seas was thinking of.
    Oct 2007
    canada
    I'm also interested in doing what gclay9999 wants, 3d models etc. A conversion of the rockcliff design with a 4 or 5 axis. If anyone has more info on doing this, that would be great.
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-30-2012, 05:43 AM
  2. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 07:31 AM
  3. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 03:58 PM
  4. 4-axis, 3+2, or 4+ axis programming system?
    By roboticist in forum General CAM Discussion
    Last Post: 09-04-2006, 02:02 PM
  5. Options for 2 Axis Head (to make 5 axis)
    By drewgarth in forum DIY CNC Router Table Machines
    Last Post: 07-12-2006, 01:37 AM
