Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 08-20-2007, 04:35 PM
huntycnc is on a distinguished road
Hot Wire for 3 axis CNC
I am searching for a method, or existing tool, to cut sytro foam SM on my 4' x 8' cnc router.
Is there a ridged hot wire available?
I have read most of the threads but I am still in the dark.
I also have woodworking software and I’m wondering if this would suffice to run the designs?
I would appreciate your insight.
Old 08-20-2007, 05:42 PM
vulcom1 is on a distinguished road
Not sure if you can hotwire cut foam with a 3 axis machine. Mine has 4 axis with 2 on the left and 2 on the right. Two are x axis and they are all independant from each other along with the two y's which are towers for the vertical movements. With yours you probably would still be using the router as I don't know where you would connect the wire.
Mine is a Hobbycnc pro 4 axis board which is reasonable and I use drawer slides(ball type) with ready rod. It is a combination of what I have seen and I am quite happy.
If you have any questions I would be glad to answer with my limited knowledge.
John
Old 10-19-2007, 05:32 PM
tager_rot's Avatar
tager_rot is on a distinguished road
Go to http://hotwirefoamfactory.com/home.php and buy a "hot knife" Mount it where your spindle goes and your good to go... I bought a hot knife for this same reason... I have yet to try it but I hope to have testing done soon. As for the software I would assume that you can set you feedrate to go slow enough to work, but we all know what assuming can do...
TagersGraphics.Com
If your to busy, Your not charging enough!
4 Axis Wire EDM Application squarewave CamSoft Products 4 09-30-2008 10:18 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
Looking for 4 Axis Wire EDM Manual BlueChip CNC Plasma and Waterjet Machines 3 07-14-2006 06:26 AM
Looping Wire Drive for axis? Dongle Linear and Rotary Motion 29 04-13-2006 10:49 AM
Bob wire 16.1 4 axis Question Uncle Buck BobCad-Cam 0 03-24-2006 08:01 AM
