Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 04-30-2007, 07:30 AM
Rypper is on a distinguished road
Using printers parts to build foam cutter.
Hello,
I have a couple of large multi-function (HP OfficeJet) mechanically working printers that I could break down for parts for a foam cutter.
Has anyone done this, are there plans available.
Thanks for any info,
Tom
Old 04-30-2007, 11:30 AM
vulcom1 is on a distinguished road
Tom,
I am building one for RC models at the moment and waiting for the electronic for it. If you do a search you should find some or the Yahoo cnc foamcutters has some also to look at.
If yours is for doing wing cores and stuff you need four steppers and preferably matched. That is why I went the purchase route. Could not get the same motors out of all the ones I tore apart.
If you need any help I would be glad to give the little advice that I know.
John
Old 04-30-2007, 12:14 PM
MnotLyon is on a distinguished road
I've got an old plotter I could part with cheap if that would be a better platform. It handles D size sheets.
Build a cheap, SIMPLE, CnC foam cutter. moreil CNC Wire Foam Cutter Machines 51 01-04-2009 08:09 PM
ideas for those trying to build '3d printers' vacpress Printing, Scanners, Vinyl cutting and Plotters 9 09-09-2005 10:35 AM
My first CNC! soon to be foam cutter nikolatesla20 CNC Wire Foam Cutter Machines 8 08-06-2005 01:48 PM
CNC foam cutter vcatalasan CNC Wire Foam Cutter Machines 7 04-06-2004 10:29 PM
Foam cutter paulried CNC Wire Foam Cutter Machines 4 10-30-2003 03:58 PM
