| CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..) |
Hi, My name is Maayan and I new to this forum.. so hi everyone. I am building a CNC machine according to www.8Linx.com/cnc. I am using the MM2001 as controller, I had some problem with the PIC: I can't program the PIC correctly, i need some help. At first I tried to program the PIC with the controller itself, but nothing happened i mean the data wasn't written to it. I took the PIC to a friend of my that has universal programmer and the EEROM was blank. of couse after the programing the 'configuration bits' are black and the oscillator is dead. I have a universal programmer the I can program the pic with instead to the mm2001 controller, I tried to it but the 'configuration bits' were blank after the programing. Is the program the writes the data to the PIC adds something beside the code? the what is the correct value of the configuration bits? What did I do wrong? Thanks Maayan Dreamer |
| WinPicProg Beta version at http://www.winpicprog.co.uk for parallel programmers (free) will let you set configuration bits and fuses. |
Look ath Benson's books, they are good, your library might be able to get one for you. http://www.sq-1.com/ When you get it working, let me know, I am interested in trying out pic and learning to program them. -Mark |
| C-Hook programing | Russler | Mastercam | 1 | 01-14-2007 09:56 AM |
| MM2001 reset (or not...) | Jalex | CNC Wire Foam Cutter Machines | 0 | 04-29-2006 12:20 PM |
| Programing book | mikeh | Laser Engraving & Cutting Machines | 0 | 03-03-2006 06:47 PM |
| CAM programing | kenlambert | G-Code Programing | 1 | 02-03-2006 01:03 AM |
| MM2001 v0.62 | JerryFlyGuy | CNC Wire Foam Cutter Machines | 1 | 12-06-2005 08:18 PM |
