Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 02-15-2007, 01:54 AM
shreifali is on a distinguished road
how to enforce foam
Hi everybody
does exist a spray to use on foam in order to make it harder.
I saw some foam planes whose wings are covered by a thin layer like a plastic layer.
I know that we can cover foam with fiberglass coat , but I am asking if there is a spray that can make the job
thx a lot
Old 02-15-2007, 02:32 AM
erase42 is on a distinguished road
yes have a look here http://www.demandproducts.com/liquidrock.html
Lemon Curry??
Old 02-15-2007, 08:46 PM
give it a try
Thx erase for your fast response
I am trying now "outdoor satin sealer" , I don't know if it will work
then , if it is still flexible , I will try to spray varnish on it , I hope it will form an isolant in order the varnish doesn't etch the foam
results to be sent later
Old 02-15-2007, 10:03 PM
something in my head is saying that shellac is a good way to seal foam against stronger coatings. shellac is alcohol based and shouldnt damage the foam. you then maybe able to coat it with regular fiberglass resin perhaps mixed with a very fine filler such as wood flour or cabasil.
Lemon Curry??
Foam cutting CNC CNCadmin DIY-CNC Router Table Machines 0 12-07-2006 02:00 PM
What is foam cut and used for? WarrenW General Material Machining Solutions 26 12-05-2006 10:48 PM
Foam for sale Sureform CNC Wire Foam Cutter Machines 2 09-02-2006 12:36 PM
Liquid foam? slawsonb Casting Metals 12 01-17-2006 04:44 AM
Have a foam question. wilit General Material Machining Solutions 3 03-11-2005 04:22 PM
