| CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..) |
| Recommendations Modify cnc router for foam Hi guys, Im after some info if anyone can help out I would appreciate it. Wish to profile cut shapes into foam, I have my own cnc router and have attempted it with a stard single sided router bit. It cuts but leaves a burred or frosted edge. I would like to get a smooth neat cut. Recommendations for tooling or a hot cutter adapted , has anyone got any ideas for me. Anything would be appreciated Steve |
| Just wondering about the foam you're using. There are some real high quality foams available used for prototyping - that give a very fine finish. REN-Board is something that comes to mind - try a google on it - you can get (used to anyway) a sample pack to try the various densities and even a small hunk of machine (blue) wax. Might check the speed and feed or the cutting tool you are using. Hope thats all helpful. Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| Thanks for the feedback, Im using the hardest foam I can find and am routing the item now with an 8 flute cutter and it seems to come up fairly okay not perfect but definetly acceptable. If anyone knows of purpose made router bits for foam can they let me know It would bve appreciated Steve |
| foam milling Hi , SIMSO , there is some to chek. http://www.zeim.de/schaumbearbeitung.html If you do understand german would be OK, if not - tools are made for use with "handy" machines , but should work also with your CNC. If You need some more informations you can contact me , I have made some by myself - the price is nasty at ZEIM. |
| Hey There, I am also cutting large amounts of foam with aa cnc machine. I have had your problem before many times. Mine was resolved in two ways. First, I got a drill bit that was specifically designed to cut foam. It was hard to find for me but i found from a company name ONSRUD. If you know of any other let me know. Also another big issue was my cutting speed and travel speed. It took me long time to adjust that. Comes with experimenting. Also, if you look at what you are cutting, if the drill bit is not designed for foam then you will have a perfect smooth going in one direction, and you will get the rough edge when the drill bit is coming back. I hope this helps Kerim |
| there is a company name ONSRUD, I buy my bids from them. they are pretty decent in foam cutting i think they have a catalog on their web page |
| BIG router bit for foam | benergy | General Material Machining Solutions | 11 | 03-21-2007 01:30 PM |
| Foam router | KrashKing405 | CNC Wire Foam Cutter Machines | 0 | 12-25-2006 06:51 PM |
| CNC Foam Cutting Router | pitsbros | Hobby Discussion | 0 | 09-27-2006 11:12 PM |
| Air Slides for Foam router? | Pat2000 | Linear and Rotary Motion | 1 | 10-07-2005 03:24 AM |
| Foam Cutter/Router | CADkathy | CNC Wire Foam Cutter Machines | 5 | 11-19-2004 10:30 AM |
