Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 01-31-2007, 05:13 PM
gguidi is on a distinguished road
GMFC help needed
Hi, All
I just finished my cnc foam cutter and have it running on foamworks
well. I am deciding what software to purchase and am now trying GMFC.
I have it running but after it makes a cut it dose not return to the
zero point on the Y axis. After each cut it gets lower and lower and
is repeatable. Dose anyone have any ideas.
Gary
Old 01-31-2007, 06:27 PM
Sleedo is on a distinguished road
I would normally expect it to get higher as you lose steps when the direction reverses. Do you have a figure in the "steps lost" field under table configuration?
EB
Old 02-01-2007, 05:51 AM
EB
Eb,
It is "0" It might be loosing steps but the error is so repeatable. If I block cut it returns to the correct "0" position. I am running 400 steps per rev with a 16tpi screw.
I am going to load CeNeCe tonight.
Gary
Old 02-02-2007, 07:56 PM
arman is on a distinguished road
hi,
for my case, setting motor too fast will cause out of shape. with slow setting it solve the problem. try lower your steps/mm value to half.
arman
Old 07-25-2007, 08:03 PM
foam27 is on a distinguished road
check your printer port mode as well(EPP, ECP, SPP)
New to this help needed! Coolcuttings Parts for Radio Control Models 10 12-15-2006 11:53 PM
Help needed widgitmaster CNCzone Club House 2 12-17-2005 04:27 PM
Help needed BlackIbanez G-Code Programing 1 11-23-2005 02:22 PM
New VMC needed Scott_bob General Metal Working Machines 1 08-22-2004 01:19 PM
what is needed for cnc kenlambert General Electronics Discussion 6 02-03-2004 08:59 AM
