| CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..) |
| Need help with machine. Hi guys! I need your help. I am busy building a 4 axis wire foam cutting machine based on Cheap foam cutter(thread on this forum if I'm not mistaken) http://www.homecnc.org/index.php/Cheap_Foam_Cutter The PC interface will be David Andersons's DIY 4 axis board on pminmo (http://pminmo.com/4axis/4axisinterface.htm) and the controller will be the PICStep controller on fromorbit (http://www.fromorbit.com/projects/picstep/). Now. All I need is the software. I do not want to cut fuselages, wings, plane related parts. I want this for relatively simple forms for me to make LFCs from. What software is available to interface with this board and the 4 steppers? That's not model aircraft related? I preferably want to import a .dxf file and then cut from that, but that is not a prerequisite. Sorry for the newby questions, but I see no use in me struggling for days on end, when you have talent sitting right here. Thank you in advance guys! Ciao! |
| Hi guys! I need your help. I am busy building a 4 axis wire foam cutting machine based on the Cheap foam cutter on this forum. My PC interface : David Andersons's DIY 4 axis board on pminmo My stepper control will be : PICStep on fromorbit Now. All I need is the software. I do not want to cut fuselages, wings, plane related parts. I want this for relatively simple forms for me to make LFCs from. What software is available to interface with this board and the 4 steppers? That's not model aircraft related? I preferably want to import a .dxf file and then cut from that, but that is not a prerequisite. Sorry for the newby questions, but I see no use in me struggling for days on end, when you have talent sitting right here. Thank you in advance guys! Ciao! (BTW: I have no idea what happened to the first post in this thread. So I am posting it again as a reply.) |
