Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 12-23-2006, 09:03 PM
max_imum2000 is on a distinguished road
endmill specs for foam milling ?
i need so answers on these questions please
1. what are the best endmill i can use for foam milling ? ball, ..etc
2. how deep should go in each path ?
3. what speed should i use ? lower or higher is better ?
4. what travel speed it better ?
thank you in advance
Old 12-24-2006, 05:43 PM
afmcorp is on a distinguished road
Hello
you forgot one more question and that is which type of milling. climb milling or conventional milling.
well i would start with a 2 flute centercut for plunging. foam is plastic and is subject to heat. if you have any heat build up you will ruin the finish. the thing i would look at is using a HIGH VOLUME OF AIR to keep any chips from sticking to the endmill and clogging up the flutes. once the flutes are clogged you'll only be burning the foam. as for ball end or square end that will depend on what you're machining i.e. curved surface or flat or 3D. this will also dictate what size. you'll want the biggest endmill that you can use but your geometry will tell you the actual size. as for type of milling climb or conventional your material will tell you. make a few cuts to see how the foam comes off. does it leave a clean surface or is it raggity. so then you can program around that.
don't be tempted to go too fast and too deep. use the same basic rules as you would for metal. go less than 1/2 the diameter for side milling and less than the diameter deep.
these 2 questions should be qrouped together. based on load per tooth and the rpm you will dictate what the feed rate is. rpm is judgement. take those test cuts and visually decide. too fast will burn too slow may rip so you need to do some test cuts. the foam material i'm assuming is not a tuff cut. so you can likely make a fairly heavy feed rate. i know that when i cut a solid plastic i run up to 3000 rpm with a 2 flute maybe somewhere between 10 to 20 ipm. just depends how much i have to do. these speeds are more for a smaller end mill say under 5/16" [8mm].
do your tests then decide. you might also check out the niagara endmill site. they may have a chart on your material.
good luck
Old 12-25-2006, 08:21 AM
fractaledge3's Avatar
Fractal Pyramid
fractaledge3 is on a distinguished road
What type of foam you use? white or blue, also what type of milling? 3D or just cutting.
Then I can give you some surprising answers.
Old 12-25-2006, 03:16 PM
hello
and thanks for your reply.
by the way i have sent you an email before but i didnt get any answers from you, or maybe i did and i over looked it .
well
i use blue and white foam. (well anything i can find over here)
and i am using engraving , not cutting
actually i wanted to make a foam hot wire cutting and independent axis but i wanted to use a turn table to produce real 3D shapes, but i couldnt find any software to handle this.
so i went to making a foam milling instead
so what do u think ?
kol sana wenta tayeb, we 3eed sa3eed
Old 12-25-2006, 04:20 PM
Fractal Pyramid
Hello,
Kol sana wenta tayb, I received your Email and replied to you but I didn't get answer from you.
I am not using end mill for foam cutting or engraving , I am using a plane rod instead (like nail or end mill shank) with 20,000 router RPM , but when I need 3D milling I use rounded tip rod or V shape tip rod, also you can use wood carving tools (rounded or v shape).
Old 12-26-2006, 04:41 AM
swagman is on a distinguished road
i use rotary burs . they give great finish and can be run quick.
Old 12-26-2006, 04:46 AM
Fractal Pyramid
Hi swagman,
What rotary burs looks like
Old 12-26-2006, 11:12 AM
Sparktech is on a distinguished road
Hi. I've found that standard metal cutting endmills don't have the correct flute geometry to do a real good job in foam (or wood). Foam and wood tools require a higher rake angle and smaller core. Look for some wood or plastic endmills, and they should work fine. I've never tried the routers, but I would think one of the single flute router type tools would also work. Hope this helps.
Old 12-26-2006, 03:28 PM
i will try to get pic up for you. they work really well, don't rip up the foam.
Old 12-26-2006, 04:19 PM
Fractal Pyramid
Thanks Swagman.
  #11   Ban this user!
Old 12-26-2006, 10:13 PM
burs
2 pics of rotary burs used for foam cutting.
ID:	28019   Click image for larger version
  #12   Ban this user!
Old 12-26-2006, 10:53 PM
Fractal Pyramid
Many thanks. The photos show every thing I just can't get the meaning in English, Yes I used it before to engrave also in colored rubber foam.
