Results 1 to 6 of 6
Thread: Need Source - Timing Belts / Gears
    Oct 2004
    I am building a CNC foam cutter and am looking for a source for buying the timing belts and drive gears. Appreciate any links or direction.
    Rich
    Gold Member mxtras's Avatar
    May 2005
    http://www.sdp-si.com/
    (Beat you to it, Al!)
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Dec 2003
    Do a search through the forums here, lots already mentioned.
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    What is the standard size people strive for for a simple design, and gear reduction?
    Registered bill south's Avatar
    Apr 2005
    Try McMaster Carr. Expensive but speedy delivery and they ususally have what you are looking for!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Dec 2005
    Point of correction:
    Cogged timing belts and/or chains are used with SPROCKETS, not gears.
    Gears transmit power directly from one to the other via tooth to tooth contact.
    Ask for and/or purchase the wrong thing, and you could become highly disappointed with the parts you get.
  • Posting Permissions
