Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 08-06-2006, 09:10 PM
anthony-whalen is on a distinguished road
surfboard shaping router
I have shaped a couple of surfboards by hand and I am not great at it. I don,t want to spend the next five years shaping to become great. I have found a CNC router designed for shaping boards in Australia for about 65,000 witch I can,t afford. I thought I might try to make one. I have a realative with a machine shop that has built CNC machines and can give me sound advise. He works with metal and all I would need the machine for I polyester foam. If anyone reading this knows the motor requirments needed to power each axis. The machine I found at http://www.shapers.com.au/ will shape a board in about 8 minutes. I do not need this router to run that fast, I am going for the most economical machine for the money.
I found a set of plans that look pretty sound to me at- http://www.inshorepowerboats.com/cn...f/CNCROUTER.htm
The estimated cost of producing this machine is estimated at 5,000 dollars witch is a lot better than 65,000.
If anyone knows where to get plans for a router with an x axis of at least 24 inches, y axis 96 inches, and z with about 12 inches.
Old 08-06-2006, 10:34 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
I'm not sure about plans. Something that I'm thinking about buying is from http://ez-router.com They offer all the electronics, minus the stepper motors, assembled in one package, and it includes the Mach Control. If you add up all the materials included plus labor for assembling
the parts, then it looks like a good deal to me.
Here is the Link: http://ez-router.com/catalog/product...products_id=51
Old 08-06-2006, 10:48 PM
much thanks!
Old 02-06-2010, 02:30 AM
meanshapes is on a distinguished road
Here is a link to a surfboard shaping machine and custom software www.precisionshaper.com
Old 05-05-2010, 01:35 AM
The issue is the software to run it efficiently will cost you $6000 USD. here is a link to our kit machine http://www.precisionshaper.com/preci...er/PS.K47.html
You can also get some info about our software... All of our machines come with a lifetime software license.
Old 05-05-2010, 12:43 PM
307startup is on a distinguished road
You should get together with this guy: http://www.cnczone.com/forums/showth...602#post771602
