Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
Old 06-21-2006, 08:14 AM
*Registered User*
hien100881 is on a distinguished road
Help me please !
Hi !
I Nguyen Van Hien from Vietnam, I have the EDM wire Japax model EE9 JL20 computer model Nec PC-980I UV Personal computer but my floppy start ( 2 floppy A ) can not use ,If you can please send me your coppy or give me the link to download .
My email : automationshop@hcm.fpt.vn
Thank you
Old 06-22-2006, 10:34 AM
JRoque is on a distinguished road
Try cleaning the floppy drive head. If that fails, slightly move the floppy left/right while inside the drive and you PC is starting. The idea is to correct a possible head misalignment. If that works, immediately make a disk copy to a blank on that same drive.
JR
Old 06-22-2006, 11:41 AM
*Registered User*
HI !
Now my Floppy A is widowed , so I can not run this machine , I think I need the floppy start
Thank you
