| CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..) |
#37
| How do you set the configuration in GMFC program ? I have a regular 3-axis cnc board that i'm using on my foam cutter. GMFC does not seem to pick up this board. Any manual configurations like Foamworks?
__________________ Live life like you never see another day |
#38
I think its a combination of two things.. on my 3 axis machines I have a Xylotex board, one is 3 motor setup .. the other is a 4 motor set up using, TurboCNC and Mach2 .. those programs don’t seem to care if the control board is powered on they just run.. I noticed on my foam cutter GMFC will not run unless the control board is powered on the board is a HobbyCNC unit. so I think the GMFC is looking for a signal that its powered on, maybe even that each step is taking place... ( but don’t “” me on that.. ) Mostly I just followed instructions on how to wire up each board.. and it all worked :-) Venomx999, What is the 3 axis configuration look like for foam is it the same … Did you just replace the router ..with a heating element ? Hmmm.. In GMFC the pin direction and Step pins are all under Windows Device Manager, But for me I did not have to change anything the defaults here good.. Not sure if any of this helps you.. |
#40
| The plastic fittings on the stepper shaft came from my local hardware store, I truly don't remember what they were intended for but they were just the right OD and ID for my needs. I drilled and tapped them from the side to mount a setscrew. Sorry I don't have any more detail. EB |
