| cutting parameters I'm doing some experimenting on wire size, foam, kerf, speed, and heat in order to get the best possible results. I'd like to know what others are using.
Do you use a fast, hot wire or a slow, cool wire? Please list all applicable parameters.
Example,
I get a 1.3mm kerf using .025" (.635mm) stainless steel wire at 3.8 amps and 4mm/sec. The foam is the large open cell polystyrene often used for flower arrangements or building a homebuilt composite airplane. I get about a 1.8mm kerf under the same conditions except a 2mm/sec speed. |
