Results 1 to 10 of 10
Thread: Can somebody build this CNC Router for foam
    Nov 2011
    Can someone build this CNC Router for foam cutting? Would like to have a large foam cutter that does the same as the zystech.com (minus the proprietary telescoping actuator) cutter but for less.
    Any positive advice, tips, or guidance is greatly appreciated.
    Attached Thumbnails Attached Thumbnails Can somebody build this CNC Router for foam-cnc_router.jpg
    Registered CUTCNC's Avatar
    Oct 2011
    China
    we offer 2D foam board cutter, I think you need a 3D cutter
    [URL="http://www.cutcnccam.com"]sample maker [/URL] [URL="http://www.cutcnccam.com"]cutter plotter [/URL] [email]sales02@cutcnccam.com[/email] Skype: trinityhu,QQ: 1393674468
    Jan 2010
    Are you still looking for a machine like this?
    Jan 2013
    Quote Originally Posted by blake374 View Post
    blake374 I am looking for a machine like this.
    Nov 2011
    The machine that I would imagine would be the best would come from Big Cnc Routers and Hotwires . They advertise for full scale machining.
    For my personal project, I think it would be economically logical to simply hire a company & utilize them until my business got off of the ground.
    This guy has a very detailed blog, dp vehicle home, & documents the cnc machine build process.
    Apr 2007
    Quote Originally Posted by Doctor Bombeii View Post
    This is a buddy of mine. He has equipment in that size range and does car body forms, etc all of the time for people. If you have a drawing, he can build from that, but can also scan in your hand made small model and enlarge it to scale.
    ADM-works.com
    Registered RCWorks.com's Avatar
    Feb 2008
    That machine is not hard to make... How big do you want it?
    Nov 2011
    Which one are you referring to? The machine that was first posted or the evolution of that machine posted in the links?
    Nov 2011
    Quote Originally Posted by harryn View Post
    ADM-works.com
    Looks SUPER EXPENSIVE. There are companies out there that can do this type of work. I've had several PM's from people on the forum. However, I just do not have the budget of Disney, Ford, Boeing, Sony, Pratt Whitney, Hyundai or any other of those companies on that website you posted. Thanks for the link though
    Apr 2007
    Hi, I didn't mean that he would build the machine for you, I meant that you could use his services and equipment until your own business client base is large enough to justify owning your own capability. His prices are competitive with the market or he would not still be in business.
    1. Newbie - To build or not to build Router/Plasma Table
      By dfranks in forum General Waterjet
      Last Post: 04-08-2011, 12:16 AM
    2. Build a cheap, SIMPLE, CnC foam cutter.
      By moreil in forum CNC Wire Foam Cutter Machines
      Last Post: 01-04-2009, 09:09 PM
    3. Using printers parts to build foam cutter.
      By Rypper in forum CNC Wire Foam Cutter Machines
      Last Post: 04-30-2007, 01:14 PM
    4. Foam router
      By KrashKing405 in forum CNC Wire Foam Cutter Machines
      Last Post: 12-25-2006, 06:51 PM
