| CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..) |
Hi everyone, New to the board, built my new foam cutter using Hobbycnc board and motors, but am having trouble with building the power supply out of a computer power supply. Anyone with experience in this care to helo me out a little? Walt |
| Well I tried to convert a pc power supply per the instructions from hobbycnc, but I am not getting any power at all. I am a little confused as to what kind of power supply it is, at or atx as the computer I got it from says it is a atx but I looked up the part # on the internet and it says at. Atx power supplies also are supposed to have a green wire and the only green one that I see is the ground wire. I have not installed a switch yet either which may be the whole problem but I do not know which wires to hook up to the switch. Any clue? Thanks Walt |
| whats the voltage for this hot wire, how many amps does it need, does it need to be adjustable, does the power supply work ( tried it with a computer) are you activeting the power good line on the power supply. does the fan turn. did u try it with an old hard drive or something like that plugged it. did u put a volt meter on it to see if u get 3.5, 5, 12 volts. ps: these psu's are small, quiet , but they can kill you, be carefull. let us know |
| Maybe it will be help you.It is the electrical circuit of a power supply for a foam cutter. http://nsrca.org/technical/tip_trick...wer_supply.htm |
| a computer power supply is not a good replacement for this foam cutter power supply. look around at electrical places or ask the guy in the next electric contractor truck you see stopped. ask for a 24v controle transformer at 2 amps or more. if you are lucky $15. |
#12
| http://wiki.ehow.com/Convert-a-Compu...b-Power-Supply this should answer all your computer power supply questions. |
