Results 1 to 8 of 8
Thread: power supply for 2mm hot wire
    Aug 2011
    Indonesia
    Talking power supply for 2mm hot wire
    i Just stuck with 2mm gauge nicrome wire, i want to make some turning table arch shaper. but i dont know how to heat my 2mm nicrome wire.
    anyone here can help me?
    I have a 24 volt 20 Ampere power supply, i use it with 1mm nicrome wire, and it can produce a good heat for the wire.
    than i try it with 2mm nic wire. the wire just warm.
    what is the problem.
    do i have to make a new power supply?
    or i can modified my 24volt 20 amp power supply, that can heat up my 2mm nicrom wire?
    is there anyone have try this? Help me please
    Oct 2005
    aaabeee,
    Quick answer to the power supply is yes you need an supply with more voltage.
    As wire length or Diameter increase more voltage is needed to push enough amps to heat the wire to the cutting temperature.
    I suggest to make or buy an adjustable supply of minimum of 50 or 60 volts. Commercial supplies of this size are very expensive.
    I use an home made supply of aproximate 8 amps 50 volts, controled by a light dimmer, to control the voltage to the wire. My bow is 54 in. long with .014" Rene wire and it takes about 28 volts maintain 1.2 to 1.5 amps cutting temp.
    Harold
    Registered neilw20's Avatar
    Jun 2007
    I used an AC arc welder with adjustable choke.
    If it puts out too much power, put a 1 bar radiator in series with the mains input side.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Aug 2011
    Indonesia
    Thanks for the answer
    neilw20
    Sounds so dangerous..hahaha
    radcliffe
    you mean that i just have to increase the voltage not the current?
    Jun 2007
    If it is wired in through a junction box, with a supply plug, and an outlet plug and even a switch, ensuring the earth wires are all connected, just don't put the radiator where it will set fire to something.
    For years we choose not to put our fingers in radiators for obvious reasons.
    You can do anything the wrong way, if you choose.
    At least some questions have been asked.
    The output of the welder is isolated from the mains. so where is the problem? Well the hot wire could be dangerous.
    You will get 40vAC on the high current terminal, or 80vAC on the 'special' terminal.
    Oct 2005
    aaabeee.
    radcliffe
    20 amps. is enough for the wire. You need the voltage to push the amps. You have double the wire size so you need to double the voltage or more to be able to push enough amps. to bring the wire to cutting temp.
    You will find that different foams take different heats on the wire. At present I only use the white beaded foam for making wing cores for my RC. planes and it only takes between 1.2 to 1.5 amps. to get a good smooth surface.
    I use DC voltage instead of AC for I intend to use a 4 axis cnc machine in the future and use GMFC software with controler with auto heat control. http://gm.cnc.free.fr/en/index.html
    I have everything except I havn't built the machine yet.
    Harold
    Oct 2005
    aaabeee,
    Here are some pics. of my supply. All load test are using 54" bow with Rene Wire.
    [IMG]C
    Hope this helps you.
    Harold
    Attached Thumbnails Attached Thumbnails power supply for 2mm hot wire-bow_power_supply_schematic.jpg   power supply for 2mm hot wire-inside_view_front.jpg   power supply for 2mm hot wire-inside_view_rear.jpg   power supply for 2mm hot wire-inside_view_front_front_2.jpg
    power supply for 2mm hot wire-left_front_view.jpg   power supply for 2mm hot wire-lowest_output.jpg   power supply for 2mm hot wire-max_output_load.jpg   power supply for 2mm hot wire-max_output_load.jpg
    power supply for 2mm hot wire-voltage_comparsion_1_.jpg   power supply for 2mm hot wire-voltage_comparsion_1.5_.jpg   power supply for 2mm hot wire-voltage_comparsion_2_.jpg
    Jul 2010
    UK
    Car battery charger
    Hi
    I've had good results with a light dimmer switch connected to the input of a car 12V battery charger. Most have an ammeter on them and I adjust it to between 1.5 to 2.0 amps. You can see my results at RC SuperVC10 build about half way down the page. Wasn't using CNC then but I'm in the process of building one. I cut both white foam and XPS. I foudn XPS need about 2.0 amps and white foam was a bit less.
    hope that helps
    Keith
    1. CNC router table to cut mostly foam and some light wood.
      By rcbamm in forum DIY CNC Router Table Machines
      Last Post: 10-24-2011, 01:13 AM
    2. Need Help!- Vertex 4'' Rotary Table hard to turn
      By ngwanhoe in forum General Metal Working Machines
      Last Post: 01-03-2011, 11:14 PM
    3. X2 arch help
      By Eritex Inc. in forum Mastercam
      Last Post: 11-23-2010, 08:23 PM
    4. My big moving table design for foam...
      By glintid in forum DIY CNC Router Table Machines
      Last Post: 02-23-2010, 07:32 AM
    5. Design & Cut Arch
      By krazycnc in forum General CAM Discussion
      Last Post: 08-26-2005, 10:06 AM
