Results 1 to 5 of 5
Thread: PDF files, multiple lines, RC foam cutting
    Registered red2's Avatar
    Jul 2011
    Question PDF files, multiple lines, RC foam cutting
    Hi. Total CNC noob here. I want to use a cutting table to cut 6mm depron foam. I found PDF files (plans) for an RC plane that I want. I converted the PDF file to DXF, but a lot of the lines in the plans are many lines, one on top of the other. The cutter would try to cut the same line, maybe a dozen times, all over the plans. The "cut file" comes out too large, for the number of parts being cut.
    I need software that takes all of these redundant lines in a PDF or DXF drawing, and converts them to a single line, in each case of multiple lines. I can't be the first guy who needs this, but a few searches of the forums here did not help.
    Thanks,
    Red2
    Apr 2005
    South Africa
    I use a combination of Notepad, Profscan, MSExcel and Solidworks to make custom Dat files for my CNC foan cutter.
    I don't think there is any software that can remove unwanted lines by itself, how does it know what to keep and what to delete???
    You will have to find a combination of programs that can do what you need.
    Emanuele.
    Jul 2011
    Quote Originally Posted by cncshaper View Post
    Emanuele.
    Emanuele,
    A single "screen capture" of the complete plans would do the job, if it could be made into a DXF file (or something just as good), rather than a pixelated picture file. All redundant lines would be shown as a single line, then, and no important lines would be lost.
    I can't see how NotePad would be of any help, unless I was editing a text file of data points by hand, to delete the redundant lines.
    Thanks,
    Red
    Apr 2005
    South Africa
    Hi Red,
    Are you using a hotwire or router to cut the parts and what software do you use to control your machine?
    Jul 2011
    Newbie PDF files, multiple lines, RC foam cutting
    Hi Red,
    cncshaper,
    BobCAD handles the drawing/editing, and the machine itself runs on the manufacturer's very old native software. This software does not seem to have a name, or even a version number, other than the vendor's name.
    I would use a flex-shaft hobby grinder with a router bit, if I can find a handpiece that mounts in a .5" hole (the pen holder of the cutting head).
    http://www.ehobbytools.com/contents/media/95812s.jpg
    The CNC table usually cuts sailcloth on a grand scale with a circular "pizza-knife" cutter. The pen holder is used for drawing out the full-scale sail pattern on butcher paper, before the knife hits expensive Dacron.
    Adding a handpiece/cutter to the pen holder would be simple. Changing out the "pizza-cutter" knife for a router would be insanely complicated. I'm working within the downtime of a professional sailmaker, and when the CNC sail table is needed, my project has to be gone within minutes.
    I may have to use a hotwire, though, if no handpiece can fit into the pen holder. Any help in finding a small (0.5" diameter) handpiece, or any good alternative to cut foam, would be appreciated.
    Cheers,
    Red2
    1. Problem- Plotting files with multiple fixture offsets
      By Neziah in forum NCPlot G-Code editor / backplotter
      Last Post: 04-25-2011, 03:31 PM
    2. Multiple lines of text
      By phatjap in forum Mach Wizards, Macros, & Addons
      Last Post: 05-06-2010, 03:34 PM
    3. first attempt at multiple 3d files
      By jrj5x5 in forum Camaster
      Last Post: 02-08-2010, 07:27 PM
    4. Multiple lines in write wizard?
      By dave6 in forum Mach Wizards, Macros, & Addons
      Last Post: 08-26-2006, 01:50 PM
