Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > CNC Wire Foam Cutter Machines
CNC Wire Foam Cutter Machines Discuss DIY CNC Foam Cutting here! (R/C wing cutting etc..)
  #25   Ban this user!
Old 07-12-2005, 11:39 AM
Latexgurl is on a distinguished road
Red face Ok just to Reiterate what I am trying to do
Ok post above made me think that I might need to reiterate the full idea.
I want to have a larger scale machine for cutting prime EPS blanks for surfboards, cutting plugs for composite vaccum bagging, and at most in the future I might retrofit it for cutting balsa although that is a secondary concearn.
The actual machine will have a MIG welded steel frame that will sit on the concreate floor and will have demensions on the order of X x Y x Z of around
8ft x 4ft x 5ft in a configuration like this but with a few adjustments in the cutting, materials, and layout for better stability and to eliminate flexing.
http://www.demandhotwire.com/twister.html
My primary questions now are
Size, type, torque, power of stepper motors?
Driver boards? Can I just build up 4 or 5 of the boards from Electronic Utopia? or do I have to go with something better like Gecko or Other?
Ballscrews or something like the Ball linear track system ?
Best program to use? I have access to Mach2, DeskCNC, turboCNC? Any suggestions on something that can control the motors and the rotating center section well.
Accuracy the best I can afford for under like a $thousand all together for the project.
I already have the materials for the frame and hopefully the motors above that I bought will work, also have all the computer stuff I need including power supplies(computer and otherwise) but dont have the Driver Boards/4axis5axis Driver setup?
Once again thank you for all of your help so far and the brainstorming and the jokes, VIPER, Fusion, Mac Knife
thanks again guys much luv.
All suggestions and setting me straight are more than welcome. Love the pain!!!
ashley
  #26   Ban this user!
Old 07-12-2005, 12:13 PM
ViperTX is on a distinguished road
...like the vertical frame......so, the welded steel framing was what was on my mind as being the most economical....since we have to rotate a blank that is 20 to 24 inches wide the table frame should be 9 X 3 ft. That would give us the room to place the cutting structure on and it would have an envelope of 8 1/2' x 30" x 30". I'm thinking that anything around 400 oz-in would be acceptable. Drivers....sticking with low Amps per phase allows you to use the low-cost drivers....I would not worry about that at this time...just have a general idea.....Oops you already have the motors...no problem we can always adjust the torques with timing belts and pulleys.
If you really think you need a larger envelope....then now is the time to size that.
9 foot ballscrews are going to be about 150 each.......and another 40 for the ballnuts....
  #27   Ban this user!
Old 07-12-2005, 12:16 PM
Ashley...just looked at the torque specs....well she'll be cute but slow......torque really drops above 200 rpm....
  #28   Ban this user!
Old 07-12-2005, 04:12 PM
Red face Hi viper thanks and your right it will be slow
I might just have to put them back up once I receive them and get some that are better for the job.
Any suggestions on what I should be looking for in a stepper motor to get not fast speed but adequate speed. I am not going to be a manufacturing facility but would like to be able to do more than one board a day :-)
Thank you once again you have been a real doll about things,
Ashley
  #29   Ban this user!
Old 07-12-2005, 07:05 PM
I've got the links at work....will get them to you tomorrow....any thoughts if you want to go with ballscrews & nuts or ACME (cheaper, but require more torque)? A "doll"....isn't that like a playthingy....*smile*...yw Ashley.
  #30   Ban this user!
Old 07-15-2005, 06:14 PM
erase42 is on a distinguished road
wow i have a lot to say on this one. tell you what, email me latexgurl. Ive been cutting kayak blanks for a buddy of mine on a machine that i built in my shop. it is possible for you with a 3 or 4 axis machine a very precise blank. all you would have to so is some light sanding to take off the small ridges where one straight wire cut intersects with another. the router aspect really isnt nessesary as long as you dont need to sink pockets in below the surface. a U shaped wire loop is possible, im using something similar on another machine, however for for what you are doing the surface would probably be less than desireable. its almost impossible to "feather" one cut into the next cut. where the cuts overlap and it has to cut that very thin layer of foam, there is no structure for the melted foam to recess to so it sort of goops up on the wire till it drips off melting a deep hard hole into the foam. not easy to sand at all. anyway drop me an email and we can talk thru email if you have any questions or want to see pics of the setup.
Ed Rees erase42@Aol.com florida
ps im a friend of danny ray
  #31   Ban this user!
Old 08-06-2006, 07:30 PM
anthony-whalen is on a distinguished road
Looking to shape surfboards too!
I have shaped a couple of surfboards by hand and I am not great at it. I don,t want to spend the next five years shaping to become great. I have found a CNC router designed for shaping boards in Australia for about 65,000 witch I can,t afford. I thought I might try to make one. I have a realative with a machine shop that has built CNC machines and can give me sound advise. He works with metal and all I would need the machine for I polyester foam. If anyone reading this knows the motor requirments needed to power each axis. The machine I found at http://www.shapers.com.au/ will shape a board in about 8 minutes. I do not need this router to run that fast, I am going for the most economical machine for the money.
I found a set of plans that look pretty sound to me at- http://www.inshorepowerboats.com/cnc.../CNCROUTER.htm
The estimated cost of producing this machine is estimated at 5,000 dollars witch is a lot better than 65,000
  #32   Ban this user!
Old 08-22-2006, 03:52 PM
GAWnCA's Avatar
GAWnCA is on a distinguished road
Has anyone built their own hotwire controller and/or pendant?
  #33   Ban this user!
Old 09-13-2006, 01:26 PM
astatue is on a distinguished road
hey folks I see $25000 is a little much for a 4 axis foam cutter so check us out at www.astatue.com under 10,000 delivered set up and 2 days training.
custom designs for stand alone lathe and table router possible too. call and we will help.
Questions from a newby-(sort of) TRC1 DIY-CNC Router Table Machines 26 07-05-2005 02:12 AM
It's Alive!! (Sort of) Gashmore DIY-CNC Router Table Machines 3 06-21-2005 11:09 PM
What sort of software should I use. ynneb General CAM Discussion 2 04-12-2004 08:26 AM
What sort of router? ynneb DIY-CNC Router Table Machines 11 03-09-2004 01:08 AM
Beginner question in Expert and 2d HuFlungDung OneCNC 22 07-13-2003 03:16 PM
