well as you can see this forum is very slow, try asking in the diy router forum as there is more activity there and people using acme screws
http://www.cnczone.com/forums/diy_cnc_router_table_machines/
What do you all use to clean the ACME threads on your CNC machines? And also can you recommend a good lubricant to use. Thanks. This is for a foamlink FC foam cutter.
I use a "Dry" silicone spray lube purchased at home despot...
