Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 07-22-2009, 06:21 PM
idtkid's Avatar
idtkid is on a distinguished road
What are these toolholders?
Please tell me they are not a proprietary product. :P
I have 4 of them, all with the same "shank", this one holds a 3/8 shank bit with set screws, another holds a 1/4", 1 holds a shell mill and the last holds ER16 collets.
They came off of an Emco PC Mill 125, my tool turret has 6 more open spots and I would like to buy more toolholders though if they are an Emco only thing im sure the cost will be quite high. Thanks guys!
ID:	84881   Click image for larger version
Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125
Old 07-23-2009, 10:23 AM
idtkid's Avatar
bump
Old 07-23-2009, 11:00 AM
beege's Avatar
beege is on a distinguished road
Looks close to an ISO 30
http://www.fabry.ch/fileadmin/user_u.../PO053-060.pdf
Old 07-23-2009, 11:45 AM
Andre' B is on a distinguished road
The taper may be standard but with that bearing inplace of the flange and the integrated draw stud it is likly somthing special.
What does the bearing do?
Does it change tools while the spindle is turning?
Old 07-23-2009, 11:51 AM
idtkid's Avatar
Havent run the machine yet so I am not sure if it pauses the spindle to change the tools or not. All 10 tools remain in the turret, and the spindle simple seats on top of one and spins, no removing of the tools takes place.
They are referred to in the manual as SK-30 tool holders
Old 07-23-2009, 12:08 PM
beege's Avatar
Given that, I searched:
http://www.cut-tools.de/Tool-Holders...:::78_219.html
http://www.carbideprocessors.com/sto...olholders.html
http://www.tools4solidsurface.com/IS...-pr-18549.html
http://toolinghouse.com/NT-54300130.aspx
Old 07-23-2009, 12:10 PM
jeffrey001 is on a distinguished road
http://www.usinages.com/files/thumbs/t_cat_181.jpg
Look at this pic and compare the measurement
Jeff
Old 07-24-2009, 06:25 AM
Superman's Avatar
Superman is on a distinguished road
The bearing looks like a critical part of the toolholder
Check out
-- you only need to see the first 10 sec. for the toolchange
While looking around found this -
--or is it a worm ?? which do you think
Old 07-24-2009, 08:48 AM
flick is on a distinguished road
Wow! Sorry, but I can't help getting in on this threadjack... COOL GEARS! I would say those are helical gears, not worms. The helix is used to keep the single tooth in contact with the others for 360 degrees of rotation.
Again... very cool!
Old 07-25-2009, 08:23 AM
Because of the sliding action, I'd call them worms. Worms are actually "screws", worm wheels "nuts". Gears roll against each other. Thats why the involute form of the teeth.
Dick Z
DZASTR
  #11   Ban this user!
Old 07-27-2009, 12:11 AM
This "motive force transmission assembly" is difficult to define with traditional terms. I would still consider them gears rather than worms, because they break fewer of the rules for gears. The only rule I see them breaking for the definition of a gear is that the number of teeth is extremely low, and that's not really part of the rules, it's just traditionally been a matter of practicality. As far as the sliding motion goes, gear teeth do slide against each other as the point of contact moves along the line of action. In this case the effect is accentuated by the extremely low number of teeth. And those teeth are curved - whether it's actually involute or not isn't really material, it could be cycloidal or something else I've never heard of, but it's appears to be curved in a fashion that provides constant linear conjugate action - a property of gear teeth.
Worms on the other hand have straight flanked teeth, unless they are of a double enveloping type - and none of these fellows seem to actually envelope one another. Also, as you noted, a worm (screw) meshes with a worm wheel (nut). So which one's the nut? And why is it's axis parallel to the worms?
Looking to buy toolholders DC Tools Want To Buy...Need help! 3 03-09-2009 06:42 AM
Rego Fix toolholders garnetram General Metalwork Discussion 2 02-09-2009 11:27 AM
What is everybody using for toolholders? Adamj12b Benchtop Machines 2 12-02-2007 01:22 AM
Mill Toolholders big_mak CNC Tooling 9 08-01-2006 10:27 PM
Regrind toolholders I.C.O.N. General Metal Working Machines 0 03-26-2004 10:43 AM
