Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 07-10-2009, 05:54 PM
Oleks is on a distinguished road
What kind of collets to use with this Perske spindle?
Hi all
Need help with determining what kind of collets possible to use with this Perske spindle – DKNS1505/2. Should I reshape its shaft somehow?
Have bought it on ebay and now scratching head… It is planned to be CNC router. mostly for wood and sometimes aluminum.
I have not found any info about this model (not mach for others, newer models) and would very appreciate if someone tell or give link to relevant info – use, maintenance, bearings (type/number/how to change), etc.
Old 07-10-2009, 06:12 PM
ger21's Avatar
That's not a router spindle. It doesn't accept collets. Probably for some type of blade or special cutting head.
Old 07-11-2009, 02:47 PM
awerby is on a distinguished road
You could use it to power a spindle
If you put a pulley on it. Now all you need to do is find a good candidate (which hopefully would come with collets). Oh, and a VFD to run it with (I've had good luck at Dealer's Electric: www.dealerselectric.com).
Andrew Werby
www.computersculpture.com
Old 07-11-2009, 04:50 PM
Well, seems better(cheaper) to "ebuy" another spindle. But more wisely. Thanks guys.
Tags
perske spindle collet
Perske Spindle & Hitachi Inverter joefish Machine Problems, Solutions , Wireless DNC, serial port 1 06-19-2007 08:36 PM
Perske spindle and VFD? DennisCNC General Electronics Discussion 7 06-14-2007 05:40 PM
Looking for info on a Perske spindle HygloCompany Machine Problems, Solutions , Wireless DNC, serial port 3 04-20-2006 04:20 PM
7hp perske double collet spindle tltaylor Commercial CNC Wood Routers 1 10-28-2005 05:00 PM
Spindle motor-what kind 2muchstuff DIY-CNC Router Table Machines 2 05-19-2005 08:16 AM
