Results 1 to 3 of 3
Thread: Hold to hold tool holder while loosening nut
    Registered NXTwoThou's Avatar
    Apr 2006
    I had a collision last week that ended up tightening the nut on my ER11 tool holder to the point I can't get it off. Unfortunately everything I know about tools I learned from google and I'm wondering if there is a device that holds the taper part of a tool holder while I use the spanner on the nut.
    Attached Thumbnails Attached Thumbnails Hold to hold tool holder while loosening nut-dsc02102.jpg
    Aug 2005
    There are bench mounted tool tighteners. That being a small holder, just guessing, but here is one example.
    30 Taper Bench mount fixture
    DC
    Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
    Sep 2004
    Most CAT or BT style blocks won't work for your tool holder because your tool holder doesn't have slots for keys to sit into (shown here). Instead, it looks like you need a spanner to go into the holes near the bottom of the taper.
    I would contact the tool manufacturer; they might stock such a unit. Otherwise, you will be stuck making one.
    Chris Kirchen
  1. Hold Down
    By thebaconbits in forum Camaster
    Last Post: 05-12-2012, 09:18 PM
  2. vac hold down
    By woodman08 in forum Commercial CNC Wood Routers
    Last Post: 11-18-2007, 07:47 PM
  3. How do you get a hold of one cnc?
    By turboboy in forum OneCNC
    Last Post: 01-03-2007, 07:50 AM
  4. Material hold
    By gabi68 in forum DIY CNC Router Table Machines
    Last Post: 10-20-2006, 06:52 PM
  5. How to hold
    By MIKEB in forum Work Fixtures and Hold-Down Solutions
    Last Post: 09-04-2005, 09:50 PM
